mk1, 2, 3 4 branch stainless exhaust manifold new
will do for £135 delivered or £120 collected
pete
Edited by PeteG40
  • Replies 51
  • Views 2.4k
Hi, I'm after one of these for my 1.3 mk1 golf will it fit this? thanks.
should fit yeah as far as I know...
I know a guy has one fitted to 1.3 golf - but his is now a gt! which has a later head. early solid lifter heads could be different. Think the gasket part number is the same (will check) if it is then bolt spacing etc is the same and shoudl be fine
I'll take it :)
do you have more than one of these? haven't got the money for it at the mo :(
do you still have this for sale ... ???
people pm'd
I'll take this if it hasnt sold already.
mark has one - but i have two!
What make is it? Does it have the lambda boss welded in? (can't see it but though I'd ask). :)
If it ticks all the boxes, can I have it off you at tatton in a few weeks? :unibrow:
bump...
have managed to get hold of another two of these from my german contact if anyone wants one?
pete
Is it a straight fit or will it need extra lengths of pipe putting in an reducers etc?
It doesn't but I could stick one on for you if you decide to buy one Gaz :-)
if your exhaust is the same diameter then you won't need a reducer. Sorry for the sarcastic reply, but i suppose it depends on the exhaust. This is 1.75" outlet diameter, which i belive is same or similar to a gt or g40 mid box.
just out of interest does it clear the charger on a g40?
think its down to what pulleys/belts you are using. Can't really say yes or no! also you might have to grind the charger outlet dome slightly.
bump - got one of these left
pete
can i pay with paypal thanks jhp
sure can - sent u pm
I am interested in this if you still have one available.
Do you know if 1.75" is the standard manifold/downpipe diameter?
yeah got one left, its about the standard size for g40 and gt
if it will it will fit my mk1 golf 1.3 and you will let me have it for 115 posted then i will take it Cheers Linden
phataz1 has one fitted to his mk1 golf but its a gt engine i think. and no - £135 is lowest i'd go posted.
pete
bump... still got one of these left if anyone interested?
pete
bumpage!
