removing roof lining 6n2
i want to take out my roof lining and pillars to re trim them, i was thinking of just covering them in glue, sticking the fabric, and then stapling it tight so it doesnt sag, but I'm stuck on how to remove the roof lining because of my sun roof/sun roof controls, can anyone help?
  • Views 3.2k
Not sure if its the same as the non sunroof model, but my 6n2. You basically fold the sunvisors down, there will be screws holding the clips in. Next to the interior light, there will be another foldy thingy, pull it down and undo the screw underneath. Then pull the grab handles down, lift the flap up and undo the screws. Pull the a & b pillar trims away and it should slide straight out the boot. Bit fidley but easy to do :-)
Thats how i done mine 2
