6n2 Steering Wheel
So i've spent 5 hours of my day trying to release the airbag unit off it's stupid little clips. After 3 hours i managed to release one side of it. Then forgot to wedge it and accidently pushed it back in. I even cut away some of the rubber from around the holes to improve access but that's not helping either. And have spent the last 2 hours trying to re-release it to no avail. The Haynes manual is more than useless and all the guides say just be patient. Well i've run out of patience and am now thoroughly pissed off with it. If i ever find out who designed this stupid clip system i am going to go and kick his head on for designing such a crap way.
Rant over,
Fred :mad:
oh, anyone got any other ideas on how to release it? Would a crowbar do the job??
  • Views 1k
1) find tree
2)drive at tree
3) heal wounds
4) cut airbag off
5)?????
6) profit!
Go get the official vag guide off club lupo.
I can have mine off in under a minute, you've either got it or you haven't.
/quote]
Cheers, just had a look and tried it but it still don't want play ball :( Guess i just havn't got it. Really want to get my new wheel on though :(
yeah same, theres a technique to it :lol:
The clips are pretty straight forward to release and you need a small flat blade screwdriver to do it.
If you dont know which way your poking you'll be there for hours!
Small flathead screwdriver inserted along the outside adge of the hole. When the driver gets to the end lever it inward towards the centre of the wheel, that's the way the clips need pushing to be released. Remember to pull up on the airbag unit at the same time, and wedge it open when doing the other side. Did mine last week and it's a real pain. Also make sure you centre the wheel before you pull it off so you know where to line up the new one so it's straight.
and before you remove the wheel, Undo the torx screws holding the horn wiring on! If you dont you end up with a big wiring mess lol
