[WTB] AFH 100hp engine + mk4 polo dashboard + mk4 polo rear disc conversion
if any one has any of the above preferably in north uk please let me know
need engine + ancillaries and wiring loom
everything for conversion into mk1 golf
as for rear discs I'm looking for these parts
right side
stub axle =6n0501118
hub complete with nut and cover and ABS ring = 6x0598477
splash shield = 6n06 615 612
brake disc = 6n0 616 601a
bolt stub axle to beam =n90758901 (4 of per side) M10x30
bolt for brake carrier =n90740301 (2 of per side) M10x1.25x30
left side
stub axle =6n0501117
splash shield = 6n06 615 611
cheers Ben
  • Views 967
use the mk2/3 golf gti rear brake setup. If you need a compensator then sirocco inline ones are the easy answer.
i am led to believe that the polo setup uses better bearings?
also thought the weight of the mk1 golf would be closer to the polo than a mk3 golf
was planning on using a brake bias adjuster so i guess this wouldn't matter to much
hey you say your after the dashboard what exactly are you wanting I've just took mine out of the one I'm breaking
ideally would need the complete dash + clocks + wiring loom
its going in a mk1 golf with an AFH engine so might just try and keep the complete mk4 wiring system so may need fuse box
also would like the dash in black rather than gray
cheers Ben
I have an engine, loom , dash etc sat on my front. Thats pretty much all thats left in the shell. Only snag is I'm in Leicester
the loom is sold i have dash and clocks in black toh. no glove boxes tho
