am i ok to use fibreglass in my engine bay
no cocky remarks if you can resist. obviously i know fibreglass is used on bonnets and things I'm just checking before i jump in like a bull that it wont expand/crack under the heat if i use it in my bay
  • Replies 12
  • Views 1.3k
explain what you want to do ..cant really think where id choose to use fibre glass in a engine bay
Probably for smoothing the chassis legs or something.
I don't see why it would be a problem, along as you don't wrap your exhaust in it.
thanks alot, and yeah for smoothing
post up some pics when youre done ..
its going to be a loong time but i will make a thread soon
should be ok as long as its not too close to anything which gets real hot as its not known for being fire resistant.
dont most people just weld things up and then filler over them??? check out mike (mk41.4mike) and connor (mccann) threads as theyve done smooth bays
Nnnnnnooooooooo, I'm a car painter and my bodyshop is porsche approved so we get alot of fibre glass kits i.e a gt3 spoiler bla bla bla. We bake our ovens at 60 degrees for 30mins on any job but we dont bake fibreglass, fibreglass is prone to popping and melting and cracking and the paint will start blistering so if i was you i wouldnt, justa word of advice dude! :)
the resin will be fine to use as a filler i wouldnt recommend using the matting as that will be hard work. just resin and a skim of dolphin glaze. p.s there are a few new cars on the market that use fibreglass in there engine bay. :)
top man. thanks for this, i know welding and filler is best i was just trying to keep welding to a minimum as i suck at it. cheers though, wont be using fibreglass now
no probs mate, engines get hot, you dont want to ruin all that time and effort you put in to getting it all right and a week later you find it all popping and cracking lol
Edited by borgy
Normal EL2 IN2 GRP is safe upto 76c when cured, there are also 180c high temperature resins sutable for aplications upto 180c.
