police woes :( Camber!?
i was on my way down the motor way and the friendly motorway cops decided to give me the old blue flasheys... he said the reason he had pulled me over is that my rear camber is illegal due to water spray or something?! does anyone actually know the laws? i didnt argue too much at the scene because tbf my front tires are borderline illegal but i do have tires ready to go on. ill put a pic of my camber an see if anyone can help me decide what to do next as I've got to re mot the car now to prove tho the po po that it is legal :/ any comments would be appreciated
  • Replies 46
  • Views 14.6k
bullshit that.
put the camber straight, re-MOT it, job's a good 'un.
the fact he didnt prosecute you shows he is unsure himself.
I don't know the laws but I know running camber like that it daft. Of course you're causing too much spray, the tread is poking out from the side of the car; You shouldn't be surprised.
bullshit that.
jus a bit odd bearing in mind my old e30 had more camber and so did my pulsar :/ I'm not sure on the specific laws tho and like you said he obviously wasnt sure himself grrrrr pc plod wind me up.....
Looking at the picture I'm not surprised they pulled you – I don’t know the laws but just looking at it you can see what will happen with spray
although i think is borderline asking for the police just to check your car over
They will pull you and use it as an excuse to check over your car no doubt
Don’t know why but I had the urge to do this :s
Edited by mpsheen
i would of thought they would be more worried about on 20% of the tire is touching the floor but obviously the spray is more dangerous..... back to standard wheels we go then :(
what's the distance i have arrowed? i think your tyre tread can be a few mm outside the edge of the body.
If your thinking that there thinking that they would worry about that shouldnt it be sorted out?
as far as i was aware the poke is illegal if the top of your tire is wider than the arch not the rear of the wheel? i could put mud flaps on so its not visible and collects the spray but that would look kak imo lol not sure on the mesurment ill try have a mesure after dinner
i would of thought they would be more worried about on 20% of the tire is touching the floor...
Well you just said it yourself basically, it's unsafe for you and others.
Buy some mudflaps and stick them on
Still, why cambered so much? haha
Edited by daveb142
if thats the case every lowered e30 bm is unsafe too then?
well my own lazyness really need the roll the rear arches other than it does look hard like it ;)
This is pretty much what arron0909 did with his picture
Sorry i stole your idea but need visuals to explain
(This is my take on this i have no experience with camber ect)
From a police point of view
Red is sticking out from the car even if tops under the arch
and at the bottom is my guess of how roughly your tires are in contact with the road
If the police where like Robocop and view it like this , I'm sure they have a reason to pull you over?
As if you say %20 is making contact with the road , would this make the car unsafe to drive?
I don’t know law / mot regs and that but I thought I would just mention it
if i was behind a car with camber like this i would have said it could be classed as dangerous?
Edited by mpsheen
camber is not an issue a copper will come across. probably rare for a copper to EVER pull someone with camber.
if you're happy to run that much camber then go for it i dont care, coppers will just keep giving you producers, so as long as you can put up with that, you're good to go dude :-D
edit @ mpsheen, thats about the same amount of contact a standard spare wheel would make. and on that basis i suggest 80kph max.
Edited by arron0909
Camber is usually there in racing to help with cornering and reduce understeer, also there in driftin to create greater contact when going sideways. The law on poke states that the must not be any more then 30mm protruding from the outer most part of the arch with all visible tread under the arches. So from your side I'd say your car is 100% fine the only reason he would of pulled you is that from a distance camber can look slightly rediculous from a distance behind, there only trying to keep you safe as they haven't charge you or given you any points just a warning.
Edited by Dooleyz
was it raining at the time? if not - just say, is it raining?
and just put the flaps on when its wet
When i got pulled over the traffic cops got tape measure out and the werent too keen on my streched tyers :lol: and they dident realy notice my camber 1.5 the just asked me to get another mot :/
20% was a bit of an exageration i know... I'm more than happy like it was jus seeing if anyone actually knew the laws? because if it is actually illegal i will change it if not then i will jus make sure the car is always in tip tope cond (tires ect) and jus put up with it.. the copper did say it looked nice scudding alone tho haha
lol and how did it fair in the mot fella did you put it back to standard to get a ticket on it?
no it was dry as a nuns **** mate lol
aha see this was my understaning of camber too.... i can see why it attracts unwanted police attention and I'm not fazed by being pulled because of it i jus wanted to confirm i knew where i stood so i can argue if anything gets said in the future thanks for your imput dude
With rear wheel drive and camber like that on the back wheels, yes.
But on both sides of the car.
You couldn't pass it off like that, it can rain at any time.
Prox you legend
