6n rear boot badge help?
I've removed the rear VW emblem badge from the boot of my 6n.
I don't want to smooth it. I've blacked the badge and reattatched it to the rubber/plastic backing.
I'm a bit stuck with how to re-apply?? Is it possible to buy the foam tape adhesive stuff that was beneath it to begin with??
or is there something else that i can use? I just want to make sure it will be strong enough! :-D
Cheers. Ed
  • Views 831
cheers :) only thing i have is that 2 part epoxy clay stuff you mix the inside and outside together but i don't thing it would be strong enough when it dries, goes quite brittle i think :p
I bought some number plate adhesive strips (basically 1mm double sided) and the badge fell off after 2 weeks
Going to resort to silicone now!
