mk3 fuel lines
need the following
Send & Return lines (that run from fuel pump holder, over the axle to the front of the car)
Send & Return lines from in-tank pump. (I need two sets of these)
Please let me know asap if you have any or all!
much love!
  • Replies 12
surely there must be someone out there with some fyooooool lions!
You can buy it by the length cheap enough. If you're having difficulty finding somehwere, try a kit car supplier.
the mk3 ones are all pre-bent which is the niceity, can you easily bend straight lengths without snapping
just done mine in copper off the roll on the 'rocco... Same job as brake lines but with bigger bore pipe, and no mucking about flaring the ends. costs about £20 from local parts factor.
i have a set of the long ones under the floor if you want them £13.50 posted?
Awesome you have a pm rich.
Jus need the lines from the in tank pump now ta
Bump!
Will check the ones I'm striping, you at Tatton?
Cheers man, yeah ill be there!
Just pulled them all off! LOL
Absolute hero for that phil. Please delete or lock now guys! Ta :-)
I'm breaking my breadvan I'm in oldham call me 07876031652 cheers carl
