To much gap between bumper and bonnet 9N
Would it screw into the slot in #5 0r am i being dumb lol, my bumper dont even have half those screw int bh lol
  • Replies 41
  • Views 7k
I've just tried to enlarge the picture to try an get a better view, but the resolution is so low it just gets blurred, but as far as I can see the screw #12 does go into that bracket/slide #5 ( 6Q0807183 guide profile left / 6Q0807184 guide profile right / 3.15€uros each)
Cheers, i have both brackets but dont see how theyd go onto the wings, they arnt even on the bumper though so that would explain why the bumpers sitting crap
Just printedf offdiagrams so can have a look and understand it better, can see how brackets fix on now 2 lol
The pic shows the holes (in red) in the wing
on the second pic items 7 & 7a hold the brackets onto the wing
7 N 90833801 expanding nut 4,8 /
7A N 90775001 torx socket head panel screw 4,8X16 /
Thank you very much Nige for your help. really appreciated
No probs, it does look like it has had a front end nudge at some time and someone without the knowledge has bodged the cover back into place
Here's the rest of the part number listings
bumper / front
1 6Q0807109C bumper
1A N 01024118 hexagonal head bolt / also use: M8X22 N 900 042 02 /
- N 90004202 washer 8,4X28X2 /
1B N 90969901 torx socket head fitted bolt M6X25-H-W /
2 6Q0807217 cover for bumper
6Q0807217 GRU primed
(2) 6Q0807217A cover for bumper / for vehicles with headlight washer system
6Q0807217A GRU primed
2 cover for bumper / see illustration: BT 807-10 / 'FUN'
3 6Q0807183 guide profile left /
4 6Q0807184 guide profile right /
5 6Q0805903 spoiler
6Q0805903 B41 satin black
6 6Q0807720 molding for bumper
6Q0807720 B41 satin black
(6) 6Q0807720A molding for bumper
6Q0807720A GRU primed
(6) 6Q0807653 molding for bumper center / "J.."
6Q0807653 B41 satin black
(6) 6Q0807653A molding for bumper center / "J.."
6Q0807653A GRU primed
- N 90218402 rivetted cap nut AM6/0,5-4,7 / "J.."
8 N 90788401 fitted bolt M6X16 /
9 N 90536901 split rivet B5X5,5 /
10 6Q0853665 air guide grille left outer /
6Q0853665 B41 satin black
11 6Q0853665A air guide grille / for models with fog lamps left outer /
6Q0853665A B41 satin black
12 6Q0853666 air guide grille right outer / PR-VK0
6Q0853666 B41 satin black
(12) 6Q0853666D air guide grille right outer / PR-VK1
6Q0853666D B41 satin black
13 6Q0853666C air guide grille / for models with fog lamp right outer /
6Q0853666C B41 satin black
14 6Q0854662 air guide grille / for models with fog lamps and charge air cooler right outer /
6Q0854662 B41 satin black
15 N 90972101 torx socket head fitted bolt M6X22-H-SP /
17 N 90970701
Going to print this all off, thanks for all the help guys
Ok, so after about 4 hours of faffing around and finding various things needed adjusting and doing the bumper still don't sit right. It seems as if the slam panel well its the bar at the very front that protects the rad, just in case I'm wrong. Is a few cm too low, will adjust this and hopefuly all will be well, can I just remove this or will it not pass an MOT?
Is it possible that the bumper bar has been fitted the wrong way around? like upside down? As for the MOT I doubt if the tester would be able to see if the bumper bar was there or not, just the front end would have NO protection even in a very slow speed knock!
I thought it may have but there is one bolt on the bottom and two on the top so it wouldn't be possible, it seems to catch on the lower part where the bottom grill pieces go if you get what I mean. So in theory if I got an aftermarket bumper it wouldn't have that indent part for the lower grills to clip into so wouldn't catch or am I being dumb lol
Edited by deanwt
Anyone know of any decent looking front bumpers, bin searching but can't see anything I like. Partly because there just pics of the bumper without it being painted or on the car
Ok it was'nt clear from the pics as to how many bolts held the bar in place, is there any sign of distortion on the section from the bar to the mounting plates? (areas in red in pic) as these are designed to deform in a crash as thats the only way I can see why it would be sitting that low in the bumper cover
There isn't mate, it seems to be sitting perfectly straight. Well it was as of yesterday, due to me looking to see what's up with the bumper I noticed one side of it wasn't even bolted on. It still remains a mystery lol
Even with the bumper bar as high as itl go the bumper still doesn't seem to sit properly. If I raise the bumper to line up with the bonnet the side of the bumper doesn't sit under the wing so obviously that isn't going to work.
Going to get a new bumper and get local bodydshop to fit it, whilst looking for a bumper I saw those bonnet extender thingies and was just wondering how they go on, isn't it just an extra piece that has to be welded on. This is going to be a last resort if the gap don't get sorted not ideal but at least it can't be seen
Edited by deanwt
Can you get some pics of the front of the car including the front chassis members?
Am at work mate, will try and get some over the weekend. What are you thinking?
