Best thing to use to Repair Rusted arches ?
Got pretty heavy rust on Drivers side rear arch , like all way through :( , should i grind it out and Fiberglass it ?
  • Views 1.3k
No point. If its all the way through, its time for a new arch. Which means welding. Fibreglass it and it will just spread underneath and get worse.
Agreed, new wheel arch time.
cut it all off with a 1mm cutting wheel , then weld in a repair arch would be the proper way
fibre is a bodge and wont last...although people do it
just buy a new wing bro
you realise a rear wing is welded on ? no easy task to whack a new one on
