offset alloys
Fiat 500 that I have got currently has 5" wide steelies on it et35, i've found some alloys which are 16x6j with et45, however I cant figure out whether they will stick out more or sit further in the wheel arch? and since theres a difference of 10 is it classed in mm's, ie stick out an extra 10mm?
any help would be useful sorry its not vw related
cheers!
  • Views 867
Sit further in the arch by 10mm.
Pete.
Pete.
If they were both 5j then you would be right but they are not.
Inner Clearance = 23mm LESS
Outer = EXTEND an extra 3mm
