Heater/fan led 6n2 out
Hi there, having trouble accessing the centre console mounted switchgear led - I've not had the car that long and in the dark I can't see the heater controls - it's all dark. Have unscrewed everything but can't seem to get it out to access the bulb - has anyone had this problem before and sorted it? Thanks in advance
  • Replies 10
  • Views 2.1k
is it just those lights out or is there other interior ones gone, as it could be the fuse
No the electric mirror lights in the drivers door are on and the rest ofthe dash lights and radio lights all work as they should, just the heater controls in the centre console. I'm thinking it's a loose wire or burnt led but can't get tithe back of it
Lol didn't think to look to lupos for comparison. Thanks guys for your help I'll give it a go tomorrow and let you know if I sort it
Dahboards are similar so id imagine its the same
Just the same, including the type of bulb you need.
If you have some small diameter rubber/latex tube similar size to the bulb its worth sliding it over the bulb before pulling it out. It helps with grip and if the bulb breaks it keeps the glass together. If the tube is a really good fit you can use it to actually pull the bulb out rather than pliers.
Was exactly as described in the how to guide posted earlier, ordered new bulb, thanks everyone
Yup, everythings far superior on club lupo.
There's jailbait too.
So tell me more about this jailbait...
