Has anyone used Cyclone Remote Central Locking Kits?
As title really, heres a link http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...d=p5197.c0.m619
Bargin price but I'm not sure. Its a bit of a gimic i suppose, but for 20 quid who can argue! Getting annoyed with the manual pins or is that lazy... :lol:
  • Replies 11
  • Views 1.6k
i haven't used one,but plenty been sold and good feedback
at that price why not go for it
Edited by gaz2k
Thats what i thought too :) I was going to look for a kit that would be ok to transfer to my new motor but at this price may aswell get two sets. Depending how the first on goes that is :lol:
been looking for something like this. gotta be worth a bash for £24. cant be too hard to fit?
Well I've ordered a kit so we'll see :) Work in a garage so fitting shouldnt be to bad, although electrics are the bain of my life! :/ Ill post up when its fitted. 2-3 day delivery so probably wont get done til the weekend unless i get impatient :D
It turned up today, not bad :D Plugged it all together and put it on a battery and it seems to go pretty well. Only down side i see (Which should be expected for this price) is that the connecters arent brilliant, when i was taking back apart i pulled a few wires out of them so had to put some proper ones on. Key fobs look pretty smart and not cheap tack.
8/10 for anyone considering it :)
i had a cyclone, wasnt too hard too fit to be honest worked when it needed to ok it wasnt top of range but for its price it was a good kit
So have you got it all fitted and working now? Was it hard to set up?
Electrics aren't exactly my strong point but I'll give anything a bash.
Its not fitted atm, after troubles last night, i had another look this evening while it was light and i was calm :lol: Its a tight fit (Less than a mm lol) between the solinoid and window when its down but it fits. To get around the problem i had to mount the solinoid on the outside side of the window if that makes sence, started mocking up a few brackets and such but got to get some pop rivets from work to start mouting it.
Biggest problem is that the barrel to lock on the door catch isnt connected by rods like most cars and is done by a paddle. So a bit of fiddling and a few holes gets around this. A lot more faffing than i expected but ill try and get a photo of the setup when its in.
Next problem is trying to run the wires from the door to inner A pillar as theres no exsisting holes or much space! :lol:
So not as simple as they make out then.
If you could get up some snaps when it's done that would be a big help. Didn't realise it was a paddle catch, assumed it would be your usual rods.
At the end of the day you're getting remote central locking, in a 20 year old motor. Dunno about you but I'm a lazy fucker and reaching over to unlock the passenger door is effort!
Will be a good bit of experience too :thumbsup:
Well I'm sure the kit would be a doddle if it was a more convential setup (Ie newer car) and also something with a wider door. But i shall muddle through :) Yeh it makes sence as the barrel is very close to the door catch/lock so as you turn the key the paddle just pushed on a lever on the lock, pretty simples which i suppose the whole bloody car is :lol:
Exsactly I doubt ill make the money back on resale but it does make it more sellable, and sames haha that was the inspiration to get a kit :p
Yeh true, dads givin me hand earlier trying to figure out the bracketry and that as hes good at making things whereas I'm more a parts fitter atm :lol: But I'm learning i hope lol.
Managed to get the drivers side mounted, Pictures as promised.
Had to heat the bar to bend it but itsstill strong. Quickly plugged it in and it works :)
You can kinda see where I've had to drill a hole in the lock to put the bar through and the paddle had to be removed from the back of the barrel.
