Yoof's Polo GT Turbo
Update? All good on the track last weekend?
  • 4 months later...
  • Replies 652
  • Views 132.2k
  • So next on the list of things to do was look at the rear axle- I plan on stepping up a slick size again, and had slight concerns about how floppy a standard Polo rear axle was.  Que some inspirat
  • Update time, almost finished the exhaust heat shield, just have to do around the backbox now.  Untitled by Peter Strange, on Flickr Untitled by Peter Strange, on Flickr Untitled by Pete
  • Not had much time on this recently as I've been busy at weekends with weddings, holidays and Le Mans- finally got back on it this weekend, managed to get the exhaust mounts done, cut and tack the exha
Where did you get your door cards and wing mirrors from dude? :)
  • 7 months later...
Time to bring this up to date!
Got an MOT last June:
07A91C39-A86E-4596-AADD-D2E79EDBB3F5_zps
And used it as my wedding car as intended:
17707_10155696621325191_3121693810137618
Then a trackday at Blyton:
So, Blyton Park with Club Polo was last weekend, I was using this as a shakedown for the Polo. Having not driven it on track for a few years, and spending the last 18months grafting an 02J onto the little 1.3, I had high hopes, and wasn't disappointed!
The 02J box I'm currently using has an open diff, so I knew the tighter 2nd gear corners would be difficult, but this didn't stop me having fun  ;D
So, loaded the car up on Friday night- got to Blyton early doors on Saturday and unloaded. The trackday was with MOT, who are always a friendly bunch, good briefing, and out for the sighting laps. Format would be OPL all day, with the outer circuit run in the morning, and the eastern circuit run in the afternoon. Tidy.
First (and only) problem of the day was the rubber seal on the fuel filler cap had perished slightly. The drain for this helpfully deposits any excess fuel onto your offside rear tyre, cheers. I'm no driving god, but a dab of oppo was followed by a black flag to tell me what I already knew... back in the pits some modification with a pair of pliars, a small bit of blue roll, and job's a good'un! It would be the only fix I had to do all day - well chuffed.
11822583_10153554484251940_1592113284972
So, some general pics from the day:
11794211_923015747736471_666429261744198
11017186_923172164387496_322097689042724
11705823_923172651054114_887730303001448
10988271_923172247720821_596582097452512
11782305_923015777736468_285172635050713
And an old colleague, and friend was there in his AX, with a 1.6 16v PSA engine with Saxo Cup Car Suspension (Leda from memory). A well prepared car, and well driven. This is always my benchmark and target, to be quicker. Often my driving style when we're both on track, goes from 'not very smooth' to 'f'in hell, have you got parkinsons...?' but we have fun!
Unfortunately we didn't get on track at the same time on the outer circuit, but did on the Eastern, I struggled with the first section, all 2nd gear for the polo, and all wheelspin. The AX ran rings around me here, and I'd spend the rest of the lap (straights!) catching up.
A few things I got feedback on:
- Marc (AX) is a hero on the brakes, I am not.... push pedal harder, and believe in the slicks
- Polo bounces/unsettles mid-corner
- Polo leans like a good un.
11782324_923172687720777_860700002097318
11234880_923172797720766_438718606677342
The leaning can be seen here:
11731593_923015781069801_269848520235639
So, my suspension setup is currently G40 Cup Car, a Sachs, fixed damper and standard 2.25" coilovers spring. A rate of 275lb front and 165lb rear. Unlike the Cup Car, I don’t run a front ARB- I also have a wider track, larger slicks, and the front is probably heavier. So I’ve increased the front and rear rates fairly significantly, hoping that I can continue to use the current dampers I have. Failing that I’ll look into modifying a Mk1 Golf coilover kit.
That aside, I’ve got a list of things to do before the next event, and look forward to being able to develop the car further, now I’ve hopefully solved the driveline reliability issues that plagued me with an 085 box.
Tinkering is continuing on the Polo, a few rust issues to sort on the floor pan, and I'd like to tidy up the interior too. Have some plans with the fuel tank/exhaust, and as usual the quest to save weight continues  :)
First up was a smaller fuel tank:
22843240590_d8505018cd_c.jpgUntitled by Peter Strange, on Flickr
23149430732_f6a90c5736_c.jpgUntitled by Peter Strange, on Flickr
It's approximately 15 litres - should help fuel starvation on long right-hand corners, and frees up some room so I can move the exhaust forward of the rear axle.
The main reason for the strip was to repair the battery tray, and stop the pedal box flexing in that area. Leaking bulkhead plays havoc with old stitch welding :-(
23859595150_36d9e174ae_c.jpgUntitled by Peter Strange, on Flickr
With a fair amount of work being done on the floor, I decided to make a spit - a friend was making one for his rally car too, so a material order was placed and duly delivered.
24047182982_0da3ac913a_c.jpgUntitled by Peter Strange, on Flickr
After some tea, grinding, welding, and a few laser cut pieces, it was ready:
24129163996_4770804656_c.jpgUntitled by Peter Strange, on Flickr
24047181702_cd1046e964_c.jpgUntitled by Peter Strange, on Flickr
Which made stripping underseal far easier!
23787462239_42b892d221_b.jpgUntitled by Peter Strange, on Flickr
Subframe left in at the front, to assist keeping it rigid on the spit:
23527052264_3f597880ac_c.jpgUntitled by Peter Strange, on Flickr
Inside I've begun stripping the underseal on the existing stitch welding, and I'll prepare some other seams for welding, I've also started removing brackets that aren't required, and generally tidy things up a little.
24047171182_aa02acf554_c.jpgUntitled by Peter Strange, on Flickr
Spanish steel isn't too forgiving when using a spot weld drill... hence a few 'b****cks' moments where there are some holes! Nothing a welder can't solve.
24072646401_fb79b8989f_c.jpgUntitled by Peter Strange, on Flickr
Weapons of choice for the next few months!
24155246065_cde231da7b_c.jpgUntitled by Peter Strange, on Flickr
I'm planning on an engine update too, and making the most of the 02J - so looking into some bigger tyres, and some supporting mods to go with them.
Many hours spent to get the remaining sealant/rust/paint off the floor, can start welding next week I think.
Pushed outside for a good blow down:
24125422590_d404eb5eda_c.jpgUntitled by Peter Strange, on Flickr
24421041225_bbe175c90f_c.jpgUntitled by Peter Strange, on Flickr
Then back in the garage to have the remaining paint removed:
24587203735_28b5ffdc38_c.jpgUntitled by Peter Strange, on Flickr
Some of the nastier pieces:
23959067584_b92866bc60_c.jpgUntitled by Peter Strange, on Flickr
Left me with this:
24478898482_768b8c5516_c.jpgUntitled by Peter Strange, on Flickr
24587203175_7728b51db3_c.jpgUntitled by Peter Strange, on Flickr
Be nice to start adding bits back after 3 weeks of removing them!
Completed a good portion of the stitch welding now, utter pain with the cavity wax, despite a hot air gun and blow torch for hours, it still comes flowing when you start to weld...!
24600317391_da70ee994c_c.jpgUntitled by Peter Strange, on Flickr
Penetration shots:
24600317201_108850d6e4_c.jpgUntitled by Peter Strange, on Flickr
24667636796_b0450c70cb_c.jpgUntitled by Peter Strange, on Flickr
24326162779_f342ed653f_c.jpgUntitled by Peter Strange, on Flickr
Ground down some of the less beautiful welds, and dressed all others so they're smooth.
24693835135_febbcd15ed_c.jpgUntitled by Peter Strange, on Flickr
24576067702_45b7b31db6_c.jpgUntitled by Peter Strange, on Flickr
Then started on the interior, not much to do here, only a few seams (previously did all the others when cage was fitted):
24600317041_4c1f34700d_c.jpgUntitled by Peter Strange, on Flickr
Got to flip it back over to do the other side, then make some repair panels for the crusty chassis leg, and sills. I've also got a load of laser cut plates coming to weld in over redundant holes, saves me cutting individual shapes out.
My plan is to etch prime the underside, I'm not done with the fabrication, but I can weld through the etch, and should offer some rust protection whilst it's bare metal.
Last week or so has been spent cutting out rust, welding in new steel, and plugging holes. Not very exciting, I'll be glad when it's finished.
Started with some laser cut bits:
24688879610_cc16e6f899_c.jpgUntitled by Peter Strange, on Flickr
These were to cover various different holes, some factory, others done by myself over the years of bolting many different things to the floor!
Welded both inside and out so there's no path for water to enter, etch primed before welding, which isn't as clean as welding to fresh steel, but hopefully provides some corrosion protection:
24891067571_7bab1a4ab1_c.jpgUntitled by Peter Strange, on Flickr
After that a good wire brush down, panel wipe, and spray with etch prime:
24891070251_a17b712edd_c.jpgUntitled by Peter Strange, on Flickr
The panel on the right of the picture above, is the OSR floorpan. I twatted a barrier at Oulton Park a good few years back, the 'bodyshop' who repaired it at the time, decided the bent floor was best left and undersealed over... chassis leg had subsequently rusted as had the floorpan. The rear towing eye mounts here, so I've replaced both the floor and chassis leg with Zintec, and will buy a bolt on towing eye.
Additional work, but I want the chassis to be as rust free and solid as possible. Fuel Pump wiring hole plated over too as the pumps will be mounted on the tank.
24866393622_449e4f7155_c.jpgUntitled by Peter Strange, on Flickr
And finally the spare wheel well, several rust scabs that i'll be cutting out and welding fresh steel in, I need to decide if I use a steel panel or a carbon fibre one.
24984385825_65162c6507_c.jpgUntitled by Peter Strange, on Flickr
Fairly boring update, next one might have shiney bits in it... maybe.
So, been a while since I updated this, boot floor is now almost done, just needs a plate putting in place, but the hole is useful for access currently.
Chopped the rust out and welded fresh steel in (the laser cut plates):
25113721649_f332451772_c.jpgUntitled by Peter Strange, on Flickr
Then once I'd done that half a dozen times, it was looking a little better:
25455131486_1b66671d6e_c.jpgUntitled by Peter Strange, on Flickr
The towing eye to chassis leg was all replaced, rather than re-make the steel U-clamp I opted for a JDM/racecar strap, so made a mount:
25388409651_765688f2fe_c.jpgUntitled by Peter Strange, on Flickr
Then a lick of etch prime, and welded the remainder of the rear panel back on:
25362827522_d3b6e544b8_c.jpgUntitled by Peter Strange, on Flickr
After that I needed to set the rotisserie bob on level:
25455126856_519d112005_c.jpgUntitled by Peter Strange, on Flickr
Decided a while back I wanted to put some pukka sill stands in, makes working on the underside much easier. Something like this:
So, some CDS ordered for the female recievers mounted in the sills, I can also make the stands out of this, will order some bar at some point to make the pins from.
Decided to use the roll cage feet. Not FIA/MSA approved I know, but this is by far the strongest/neatest solution. It's a pain to drill straight, but taking time (about 3 hours) and lots of measurements gave a good result:
25113717449_bd8a8b120a_c.jpgUntitled by Peter Strange, on Flickr
Outside (small hole is from the side skirt):
24850706244_c59b813b02_c.jpgUntitled by Peter Strange, on Flickr
Poking through:
24850711814_aff9fe4342_c.jpgUntitled by Peter Strange, on Flickr
I've left them a little long, as I'm going to make a side skirt incorporating the arches/floor. I'll take 0.5' as a result!
24850702914_6c37cab055_c.jpgUntitled by Peter Strange, on Flickr
Have to make some 3mm plates, plate the tube, then weld it all up. Oh and do it another 3 times...
Finished the off-side sill mounts now, there's 3' difference total between them, and a 1.5mm height difference. Only noticeable on a perfectly flat surface (assuming I can make the sill stands exactly the same height!)
Anyway, first job was to panel wipe the parts and etch prime inside the sill:
25282218153_9d82cd2ca2_c.jpgUntitled by Peter Strange, on Flickr
I made a blank for the end of the female part, so no crud can get in:
25790153672_c04aa3ae3a_c.jpgUntitled by Peter Strange, on Flickr
Slot her in the hole:
25610356570_33a26c76fd_c.jpgUntitled by Peter Strange, on Flickr
Then weld it up:
25815986461_c6a0ff677c_c.jpgUntitled by Peter Strange, on Flickr
And etch prime:
25282221353_1e65104f90_c.jpgUntitled by Peter Strange, on Flickr
The interior section will be welded when I flip the car over:
25282209913_5f32e57056_c.jpgUntitled by Peter Strange, on Flickr
And some measuring to check my handy work:
25910898505_6edb89b363_c.jpgUntitled by Peter Strange, on Flickr
Height difference from sill face to underside of receiver is 1.5mm front to rear
Then check the car is level front to rear:
25885030146_ae7c9154b6_c.jpgUntitled by Peter Strange, on Flickr
And with a piece of L-section sitting on the top of both sill receivers:
25790142162_355a87555f_c.jpgUntitled by Peter Strange, on Flickr
That'll do pig!
25790147372_35434221cb_c.jpgUntitled by Peter Strange, on Flickr
I've left them long currently, as I've not made the side skirts yet, I expect to chop 40mm or so off them.
Just got to do the other side now, and make sure the heights are consistent.
So, sill receivers are all complete, taken a fair old while, but should make working on the car easier, I'll build the stands in due course.
26192673362_a707eb9088_z.jpgUntitled by Peter Strange, on Flickr
Tubes capped off internally, and then etchprimed:
25680264694_1e8ffd36c8_z.jpgUntitled by Peter Strange, on Flickr
Then etch prime the inner sill, plate, and everything else:
26259168806_42d0a859d6_z.jpgUntitled by Peter Strange, on Flickr
Then time for welding:
26218857521_c937f747f0_z.jpgUntitled by Peter Strange, on Flickr
25680262584_78e43ee090_z.jpgUntitled by Peter Strange, on Flickr
Whilst working on the rear of the car, the grinder caught the arch... which I duly found out was actually filler. Long story short, I'd tacked the arches together before sending it to the bodyshop (post Oulton) and asked them to finish tubbing them off an tidy it up. That got interpreted to stick filler in all the gaps and paint it.
No pictures of that as it looked utter gash, suffice to say its a long old job, but if it's worth doing, DIY!
Offside rear:
26012246590_fdb8924724_z.jpgUntitled by Peter Strange, on Flickr
Nearside rear before etch prime:
25680265834_c504ab62a5_z.jpgUntitled by Peter Strange, on Flickr
25682381993_1e2f40cf78_z.jpgUntitled by Peter Strange, on Flickr
I finished off last night by removing some crusty sections of the sill, and straightening it out. As its going to have a false floor, I’ll have to extend the jacking points through this so I don’t have to take the floor off for jacks/ramps.
25682381553_157b04fcf0_z.jpgUntitled by Peter Strange, on Flickr
Also picked up a few bits for the update, EPAS column and some new rear brakes, nowt too exciting yet!
26012248540_35f875fa66_z.jpgUntitled by Peter Strange, on Flickr
So, the last few weeks I've not spent much time on the car, but have now finished removing the old harness mounting points, and fitting new ones.
Why? Well the old harness pickup points, weren't in line with the new manufacturers instructions (Schroth), and I wanted to lower the passenger seat rails and generally tidy things up.
So, better to do it on it's side when access is easy!
First up some measuring, and drawing out what I could achieve with my current driving position:
26343715053_880380d416_c.jpgUntitled by Peter Strange, on Flickr
26914750476_90de9fd16f_c.jpgUntitled by Peter Strange, on Flickr
I'm slightly out of Schroth's guidelines on the lap and crotch (by 2' and 3' respectively), but this is the best I can do with the space (short of cutting the tunnel up). My measurement error is probably that much anyway!
Ordered some ready made FIA spec plates 7/16th for the lap, ended up making my own for the crotch, as the floor is to thin, I made this plate larger than the sum of two individuals (6-point harness so 2 crotch points), also boxed the inner lap belt mounts in.
Usual process, bit of cardboard, cut the steel, tack together, etch prime the rear, weld it up, then paint:
26343714283_630c107ed0_c.jpgUntitled by Peter Strange, on Flickr
26342876264_a4188e6f22_c.jpgUntitled by Peter Strange, on Flickr
26914746956_a1552f9299_c.jpgUntitled by Peter Strange, on Flickr
26343716373_efc0ab7d13_c.jpgUntitled by Peter Strange, on Flickr
26343715743_6932bb7810_c.jpgUntitled by Peter Strange, on Flickr
26854027232_9f163730df_c.jpgUntitled by Peter Strange, on Flickr
26914749566_7867a959ea_c.jpgUntitled by Peter Strange, on Flickr
26914748206_0ea8de8929_c.jpgUntitled by Peter Strange, on Flickr
And you can see all 8 points here:
26854026022_3e5ee11751_b.jpgUntitled by Peter Strange, on Flickr
That's about it for now, I've been tinkering with a few other bits, like getting some 2008 Seat Ibiza rear brakes to fit a 1991 Polo:
26342882064_287115d0c6_c.jpgUntitled by Peter Strange, on Flickr
And the new fuel tank:
26343713003_2c4a2b6260_c.jpgUntitled by Peter Strange, on Flickr
More on those, next time!
Cut a hole for the ATL Cell, I'll add some steel angle to mount the aluminium box to, and then figure out the in-tank pump setup at a later date.
26770744340_997828f441_c.jpgUntitled by Peter Strange, on Flickr
26770744950_6d63dde1c5_c.jpgUntitled by Peter Strange, on Flickr
Onto the exhaust, handbrake cables, and under-body next  ;D
Fuel cell now installed- looks like 4 bits of angle iron (cause it is...) but there's a fair amount of work behind it!
As you can see from the first photo, the panel under the rear seat isn't flat:
Which means I'd have to break out the year 9 maths book, and get jiggy with some trigonometry.
First though, this arrived:
27195289272_38edd90409_c.jpgUntitled by Peter Strange, on Flickr
Double bevel model, so compound mitres are possible (used for this job) and I can swap the blade for a stainless one for my exhaust system :)
So, I started with the two easy angles, the front and rear- decided to pop rivet the aluminium case to the steel as I couldn't access the rear for bolts.
Onwards with the marking, centre punching and drilling!
26685025294_8cf8ffe8e8_c.jpgUntitled by Peter Strange, on Flickr
Fairly typical workbench shot...
With that done I moved onto the side which require a compound mitre cut:
27222113801_26565331bc_c.jpgUntitled by Peter Strange, on Flickr
And that ends up looking something like this:
26685978163_501becea2f_c.jpgUntitled by Peter Strange, on Flickr
A quick trim of the sharp edges and a zip round with the welder:
26685022734_9a1da40594_c.jpgUntitled by Peter Strange, on Flickr
I then dropped it in and got my weld on:
27291869545_976a0db5e6_c.jpgUntitled by Peter Strange, on Flickr
27195238902_d334e298ff_c.jpgUntitled by Peter Strange, on Flickr
And made a plate for the front gap:
27195280842_563b0c65f6_c.jpgUntitled by Peter Strange, on Flickr
A lick of etch prime:
27291914785_40b1c02ba5_c.jpgUntitled by Peter Strange, on Flickr
And then a test fit:
27291879605_940601a4cb_c.jpgUntitled by Peter Strange, on Flickr
27222105601_3833431df1_c.jpgUntitled by Peter Strange, on Flickr
Job jobbed:
26685006104_d0eb3b31c6_c.jpgUntitled by Peter Strange, on Flickr
I'll work out the fuel filler, internal pumps and fuel lines at a later date, plan is to move onto the handbrake, exhaust, and heatshield.
Not had much time on this recently as I've been busy at weekends with weddings, holidays and Le Mans- finally got back on it this weekend, managed to get the exhaust mounts done, cut and tack the exhaust system, put a big hole in the side for it to stick out, and bend the handbrake cables and make the mounts for them.
So, exhaust mounts from a T3 Transporter, brackets start as 5 pieces of flat sheet, welded together with captive nuts:
HPSTzNhttps://c5.staticflickr.com/8/7380/27452431924_9944371ed8_c.jpg][/url]Untitled by Peter Strange, on Flickr[/img]
28032222056_a8e041c447_c.jpgUntitled by Peter Strange, on Flickr
27988804441_0bf69f22db_c.jpgUntitled by Peter Strange, on Flickr
Handbrake cables from the Seat were annealed and then bent into shape, they're slightly too long for the Polo, so I couldn't sit them tight against the body, but they clear everything, and no one will ever see them!
27451857273_0e4f3784a0_c.jpgUntitled by Peter Strange, on Flickr
28065919095_b25a9d84e5_c.jpgUntitled by Peter Strange, on Flickr
Next up was the exhaust, I wanted 3" pipe and a side exit, to allow some rear axle mods, and a flat floor, 3" is fairly big for a modest Polo tunnel, but with some chopping of various brackets, and lack of gearlinkage, it goes!
28032224416_b84d7bacdc_c.jpgUntitled by Peter Strange, on Flickr
27452444304_dcf04f201f_c.jpgUntitled by Peter Strange, on Flickr
27451852393_d28183a6fc_c.jpgUntitled by Peter Strange, on Flickr
Silencer is Simons- seems fairly good quality, a crimped housing rather than welded, but had steel wadding, instead of fibreglass (which always degrades after a few years), hoping it will still pass noise limits, being a turbo it's fairy muted at no load anyway- I just about have space to put and additional one in the middle of the tunnel, if required.
Next up is bending the hangers, then onto the TIG to weld 'er up!
good god! this is quite a build, loving it :)
Hangers all complete and tacked into place:
28179696241_224e7fd121_c.jpgUntitled by Peter Strange, on Flickr
28223528216_60a845b5b2_c.jpgUntitled by Peter Strange, on Flickr
To remove the exhaust or change a hanger, remove the two M8 bolts, and take a split pin out, no wrestling with rubbers!
28223525556_9378888f5d_c.jpgUntitled by Peter Strange, on Flickr
Left it all looking something like this:
27642311894_b2b18c2854_c.jpgUntitled by Peter Strange, on Flickr
I wasn't sure what I wanted to do for the tailpipe, I've got a straight exit and a slash cut, slash cut is winning currently, looks very similar to this... given the origins of the tube that's not too surprising:
28179695901_c47c05845f_c.jpgUntitled by Peter Strange, on Flickr
27976737790_95d0e71d03_c.jpgUntitled by Peter Strange, on Flickr
Because racecar etc.
27642150423_6cf1996621_c.jpgUntitled by Peter Strange, on Flickr
Next up is plating the inner panels together (all 3 of them) which requires a few paper templates and some zintec steel, proper pain in the arse to do, but vital!
27642302754_f752e2a741_c.jpgUntitled by Peter Strange, on Flickr
All for now, currently scratching my head regarding rear axle, and mulling over pedal boxes and steering columns.
Pete
Been following this on Club G40 also. Love it!
Dare I ask if this is making an appearance at the track day or are you taking something else?
Absolutely flipping fantastic work. Looking forward to seeing the future progress!
Those photos were taken last week! So unfortunately it won't be there, I'll be in a Volvo :D
Looking good Yoof :thumbsup:
fabrication looks amazing, love these updates......
Absolutely awesome mate, love the attention to detail, doing what I hope to eventually do to mine in terms of grinding the floor back to bare metal and fixing stuff!
As usual detail is amazing , love the side exit and jack points :)
Que some inspiration from works VW Golfs:
28654015840_d99e466888_b.jpgUntitled by Peter Strange, on Flickr
28654016010_94f296beeb_b.jpgUntitled by Peter Strange, on Flickr
28654016020_2b17e31ea1_b.jpgUntitled by Peter Strange, on Flickr
So, fire up the kettle and solidworks, a few days later some laser cut pieces arrived (I have spares if anyone wants) :
28323280303_7ba17a2be6_c.jpgUntitled by Peter Strange, on Flickr
I also ordered some ERW tube and a few inserts from McGill Motorsport - good service and well priced rose joints:
28834478872_3abfd826d4_c.jpgUntitled by Peter Strange, on Flickr
So, onwards with welding things up, first up the base plate for everything to sit on:
28323258283_545cc5de64_c.jpgUntitled by Peter Strange, on Flickr
28834490052_57ab90bffa_c.jpgUntitled by Peter Strange, on Flickr
Then tack up the 4 side plates (hole will become obvious later)
28320659424_804a2eb7db_c.jpgUntitled by Peter Strange, on Flickr
Mock-up of the centre mount:
28323269223_88c8e2e06c_c.jpgUntitled by Peter Strange, on Flickr
I then tacked the insert and tube together:
28834464212_17a9916e6b_c.jpgUntitled by Peter Strange, on Flickr
28320647354_de9bcda78d_c.jpgUntitled by Peter Strange, on Flickr
Then a quick tack to the base plate, and mount the stub axle to make sure everything clears:
28320644324_98513b5511_c.jpgUntitled by Peter Strange, on Flickr
I then etch primed the inside of the turret, and welded them both on:
28323262193_1df26740b6_c.jpgUntitled by Peter Strange, on Flickr
Same for the centre mount:
28323260613_b0fef8a728_c.jpgUntitled by Peter Strange, on Flickr
28939180435_e37be9ab12_c.jpgUntitled by Peter Strange, on Flickr
Then it was time to strip it back, clean, etch prime and assemble:
28653820960_eea4cd61b1_c.jpgUntitled by Peter Strange, on Flickr
28320657854_bd9dab3eaf_c.jpgUntitled by Peter Strange, on Flickr
Holes obviously for the handbrake cables to pass through:
28834474212_7531574296_c.jpgUntitled by Peter Strange, on Flickr
And finished with some rubbers over the rose joints and plastic finishers over the nuts:
28320649784_62201a4af6_c.jpgUntitled by Peter Strange, on Flickr
So, that's some VAG parts bin raiding; Seat 2007 Stub Axles, Discs & Calipers, Lupo GTi Stub Axle spacers, Polo GT/G40 Axle, and Mk3 Golf Kit Car style toe bars.
All for now!
Pete
