Yoof's Polo GT Turbo
empty your inbox chap
  • Replies 652
  • Views 133.5k
  • So next on the list of things to do was look at the rear axle- I plan on stepping up a slick size again, and had slight concerns about how floppy a standard Polo rear axle was.  Que some inspirat
  • Update time, almost finished the exhaust heat shield, just have to do around the backbox now.  Untitled by Peter Strange, on Flickr Untitled by Peter Strange, on Flickr Untitled by Pete
  • Not had much time on this recently as I've been busy at weekends with weddings, holidays and Le Mans- finally got back on it this weekend, managed to get the exhaust mounts done, cut and tack the exha
sweet as fook mate as usual
V.nice in the 12's..
easy mate... love them front wheels you got, what are they? and the jack up at the back, does than not induce anti-squat and shift the weight to the rears? sorry i don't know much a bout making fraction from the front! fair play on the 1/4 miles too!
If you induced 'anti-squat' as you put it, you'd retain the weight over the front (where you want it), hence the high rear height and spring lb choice.
Front wheels (with drag slicks) are Mattigs, my everyday rollers are Compomotive MOs
Pete
Pete
i meant 'squat' as in the back to sink down, or do you have really hard suspension to keep it over the front? 'anti-squat' as i know it is what causes RWD dragsters the wheelie... in a normal RWD launch, you get like 60-70% weight transfer over the rears, but by the adition of something like ladder bars or 4 linking, you can send 100% of the weight back aiding traction.
How stiff are 250lbs springs?
Erm, your answer is in the question!? At the stiff end for road use...
richie_six- Not sure what you're getting at, you can't send 100% of the weight to the rear unless you lift the fronts clean off the ground, which isn't always the quickest launch for RWD anyway.
The basics for FWD consists of hard rear, weight on the front.
Hope this clears it up for you
Pete
8-)
I would say those rear springs are too stiff for daily road use, ride down and back on even a smooth motorway wasn't exactly comfy!
I've got 275lbs springs up front on my new coilovers, I'm a bit worried about them being ridiculously stiff for road use.
They will be. Who specified them for you?
Presume you've got Gaz ones...
Yep, they're Gaz coilovers.
I'll give them a call next week and say they'll be too hard. I need something stiff enough for enthusiastic driving but I don't want my car to rattle my fillings out.
What's best for hard road use and a bit of track time?
Edited by Alex
  • 6 months later...
wow, nice work dude 8-)
done for RR day yoof?
Same question lol..
very nice mate.
new to these engines. what boost are the internals capable of holding?
also what turbo are you currently using at the moment?
have you thought about upgrading to a bigger turbo to feed your boost habit?
very good work. qudos to you :)
a polo's alot scarier...lol
i doubt that very much with 2 bald tyres down the the wire lol used to be one of the fastest front wheel drive cars in the country
An amazing build mate :thumbsup: looks epic :D
Martin.
i have just read this from begining to end, thats fantastic,
if you dont mind me asking what is the engine spec sir yoof
were did u get the inlet manifold in the first pic of the engin
empty your inbox mate ;)
heya mate , whats teh spec of your engine?
if there standerd internals what kinda boost they capable of holding?
and what turbo?
if you dont mine me asking :) thankyou
If you mean the inlet for the ITBs on the GT engine, it was custom made by a friend of ours.
and what turbo?
Spec is BV head, turbo cam, 1341cc pistons, stock rods and crank. Was running a K03 at 22psi, now a Garrett unit instead.
and what turbo?
Thanks for the reply mate ,
can i ask whats a BV head...? and are the 1341cc pistons standerd g40 pistons or soemthing?
sorry not to clued up on polo's :) come from a civic background
