Yoof's Polo GT Turbo
Big valve head :)
bigger valves than standard. Am sure yoof will tell you the dimensions.
1341 are bigger pistons, standard are 1272cc
  • Replies 652
  • Views 133.5k
  • So next on the list of things to do was look at the rear axle- I plan on stepping up a slick size again, and had slight concerns about how floppy a standard Polo rear axle was.  Que some inspirat
  • Update time, almost finished the exhaust heat shield, just have to do around the backbox now.  Untitled by Peter Strange, on Flickr Untitled by Peter Strange, on Flickr Untitled by Pete
  • Not had much time on this recently as I've been busy at weekends with weddings, holidays and Le Mans- finally got back on it this weekend, managed to get the exhaust mounts done, cut and tack the exha
polo big valve heads consist of 2mm bigger exhaust valves
Big valve head :)
Thanks for that then mate. So the gt block has been bored out obviously..
the 1341cc pistons a straight fit to the GT conrods?
also , big valve head? They need to be made or do they come on a certion car?
Thanks very much for this mate , looking to go down the boost route soon as i want to do something abittt diffrent like. :)
Edited by jake_smith
Big valve head :)
i think yoof will have started with a complete g40 engine rather than converting a gt block, although it can be done. all polo conrods are the same, specific gt,g40etc conrods dont exist so 1341 pistons will fit any polo conrod. BVHs are custom with the work undertaken by a professional, i think it consists of fitting bigger exhaust valve seats in the head and porting the head to work with the increased valve size, the bigger exhaust valves can be purchased from jabba, get yourself on clubg40 theres loads of info on there about this sort of stuff
thanks
will
Will is correct, you can however use the 3F (GT) block if you want, just have to drill/tap provision for a knock sensor in the rear of the block (G40 has this stock).
Crank/rods are the same dimensions, although I feel that the G40 crank is a different material.
Recently:
8-)
Pics coming soon :-)
Recently:
8-)
awesome! did you do the cage yourself? are you putting the dash back in we need more pics :unibrow:
i bought some of the wheels you got in your first pic the other day, do you know what the proper name is I've been told like 5 different names, and what spacers was you using on the front to clear the brakes?
Atiwie 7x13 ET20, also in ET3. I used 20mm spacers at the back, 10mm at the front.
As for the car:
8-)
Just read through all of this.
Nicely done man... that is seriously quick in the video from the pod!
Will be keeping an eye on this!
Marcus
I love this car :D
where did you get this cage from? and how much was it if you dont mind me asking
Polo-PP :-D
To a customer about £1200 :-)
scweet!
no girls in short skirts getting in that one! ;)
are you going to PPC in the park?
Pete
Not sure, although I have found their adverts comdey classics on youtube for it :-D
Starting back on the car this week :-)
Looks imense mate! :thumbsup:
How did you get rid of the little stem on the front arches? or are these some aftermarket ones?
those 2 mm bigger valve are also available from gsf lol £6.50 each just need to no what you looking for valve seats will be done when you take the head to have them re cut to house the 2mm bigger seats any one no of anywhere around yorkshire that can put new valve seats in?
your car is awsome yoof nearly the same speck as my engine for the mk1 golf apart from a couple of extra bits I'm using that I'm keeping a secret till the car is done ;)
i have respect for this car man ;)
good to see people have the motorsports state of mind !
enjoy it
this car has made me get a mk3 and I'm not even joking! cars in forsale section lol. AWESOME work
  • 5 months later...
I've recentley been working on my car again, after slicing my thumb up a treat:
I had to have some time off from cars (11stiches in my left thumb dictated this!) and got a few customer conversions out the way too. So work could commence, a few teaser shots:
Seat mounts now in for the buckets:
Repaired the bulkhead (I'd previously but a hole for the throttle bodies):
Couple of pics showing quality and fit of the cage:
As the whole shell is now stich welded, I've got to remove all the underseal on the opposite side of the panels and reseal or paint it:
Getting there slowly:
Am hoping to be at Club Polo RR Day, but we'll see, it's almost November and the car's still a shell!
x2
seriously inspired by this car, made me buy a mk3 the other week!
Absolutely stunning work! You boys don't fuck about!
Once i have a car that goes, turns, stops, this is the next stage. What steel did you use for your cage? 45mm T45? And also how did you go about the mitres?
I notice you havn't gone through the bulkhead with your strengthening..
Top mounts look the business! Projects like yours and dogwoods over on cgti make me want to start again. True inspiration!
I'm feeling your pain.. had to have 11 stiches in my arm after slicing it open on some laser cut stainless at work the other day :cry:
All the way through to the bulkhead :-)
And triangulated to the A-Pillar upright:
Cage is 45mm CDS- with cage certs supplied, the polo is already so light I didn't see the advantage of T45 for the extra cost.
Glad you like, we'll be offering the cages on our website soon :-)
Aah yes, spot on. I have been building up a vision in my mind of how to go about strengthening my mk3 shell.. and it has finally been completed!!
I'd like to weld it in myself, but working out all the dimensions, bends etc is just a massive minefield. Will you be supplying them in a "kit form" unfitted. Or is it a case of bespoke weld-in only?
Incredible work, one of the only threads i read on here!
