Yoof's Polo GT Turbo
Top notch!
  • Replies 652
  • Views 133.5k
  • So next on the list of things to do was look at the rear axle- I plan on stepping up a slick size again, and had slight concerns about how floppy a standard Polo rear axle was.  Que some inspirat
  • Update time, almost finished the exhaust heat shield, just have to do around the backbox now.  Untitled by Peter Strange, on Flickr Untitled by Peter Strange, on Flickr Untitled by Pete
  • Not had much time on this recently as I've been busy at weekends with weddings, holidays and Le Mans- finally got back on it this weekend, managed to get the exhaust mounts done, cut and tack the exha
:drool: Stunning car mate
You planning on using the inner door handles as grab handles then?
Think that's what I'm going to have to do on mine , using MDF covered with leather.
M
This is, hands down, the best Polo in the country.
I'm not just saying that either.
+1
Perfection in my eyes, wouldn't change a thing!
What was used to paint the underside of the car? Wouldn't mind doing mine at some point, looks like a really good finish!
Edited by deviance
Aye its alrate is that!
Cheers for the comments, not sure it's the best! Not set out to make a show car, just something that interests me and is fun :-D Rest assured I'll still rag the crap out of it :-)
Seats both bolted in now- took all day to get them right:
And finished off the speaker grills:
Track control arms now built up and greased:
Is it guna see any 1/4miles action again Pete?
looking epic dude, hitting any santa pod shows this year?
Stunning!
Yeah for sure! Not sure if I'll go much quicker than 12.5- but we'll see :-)
Yes I'll be at GTi Festival (car won't be at spring fest though)
Stunning!
Cheers dude, look forward to seeing yours too!
Stunning!
fook mine, this is where its at! everyones eyes will be on this weapon
wow what a car love this thing and where did you get the tca's take it that they make it camber ajustable?
I'll keep my eyes out for it, i'd like to see mid 16s on the motor and mid 14s on the bottle out of mine.
We make the TCA- see www.poloperformanceparts.co.uk
Popdragin- I recorded a low 15 on my GT with gas, although I think it had a 14 in it to be fair- that was with an 80 shot :-)
Anyway:
Back end is now complete bar fuel lines, new axle mounts:
Put the axle on 3 times to get it square to the chassis, bit of a pain but worth it:
And then put the diffuser on:
And then the wheels:
that car is filthy :unibrow::drool:
Looking good!
With the rear beam mounts, you said it took three goes to get it on squarely. Could this be a reason why some Polos lean?
Alex- I was setting the rear beam to be parallel with the track of the car, as there's alot of play in the rear mounts it's easy to get it wrong and then the car will 'crab'. I've got 4 wheel alignment gauges but can't use them until the engine/suspension is in- hopefully it's correct though as taking the rear beam off to adjust it is abit of a pain (exhaust, diffuser would have to come off).
Polos leaning I think is partly due to tolerance stack up between OEM and aftermarket components, and if the car often travels with just one person in, one side will have up to 100kg extra load than the other, so not surprising after 15+ years it's settled slightly lower.
Hmm. Back to winding the coilovers up on the driver's side I guess. I just don't get why a car with all new suspension would still lean. Old shocks I get but fresh stuff should sort it, wouldn't it?
Something must wear out or sag in that time, in which case it can be replaced and it'd sit properly then.
Not questioning what you're saying, you know Polos inside and out better than I do. I'm just out to cure the root cause of the lean, rather than wind up my coilies to cover it up. Unless they leave the factory that way, in which case I'll settle for getting the C spanner out.
Sorry for the thread divert!
It's fine, I wouldn't be surprised if the shell is bent slightly- mine is now a large amount stiffer (hello cheeky) and the shell itself when on 4 axle stand on flat ground will rock on the stands.
When you actually start measuring alot on the polos you realise they're not very straight to start with, wheelbase, track, stock camber etc. Hence making everything adjustable on mine :-)
The only other thing about suspension is leave the rear axle to mount bolts loose until the weight of the car is on the rear beam, the mounts have a tendancy to pinch the rear beam bushes, which won't help matters.
So do you now get the adjustable TCA's as part of the Stage 3 subframe?
Matt.
Nope, they will be priced at £200.
do you sit in them seats and make car noises?
Of course!
180630_495940386226_637311226_6732626_63
hahahahaha
