How bad will it be?
  • Replies 19
  • Views 1.4k
Well damage would be if someone tried nicking it.
Start it up every now and then, roll it and check tyre pressure.
Yeah well I'm moving it to my Grandads house it will be safe there, Wont the brakes lock up and that?
Well no unles you dont plan on moving it for 4/5 years.
Leave the handbrake off ash, and just leave it in gear and shove a block of wood behind back wheel if your that anal :-D Thats how ours has sat for all these months, started up every week until shes warm and then covered back up again when its cooled down :-(
Yeah i might need to charge the battery haha, I need a new thermostat!
Funny you should say that, came to move KG3 today (RHD) after about 4 years (last tax expired in 2008 and it was still the envelope) and although it started with a fresh battery the front breaks were locked solid. Still not bad to start on the key after so long.
I'm sure a little wiggle in the car freed up brakes?
No totaly solid sadly, probably going to need stripping down.
what about rust on the brakes? will the pads get that off or should it be scrubbed off?
I really need to give my car a quick rip up the road
Brake discs get surface rust after a few days of not doing anything, using them clears it off most of the time.
just leave the handbrake off. no need to worry about anything else if it's only for that long. mine sometimes sits in my garage for longer than that when I'm not using it. In fact I haven't driven it since a track day in last november
id just disconnect the battery and ideally whip it out, as long as you heed as said above and leave the handbrake off.
also if its laid up over winter, ensure and this is an absolute must, that there is enough antifreeze in the coolant, as otherwise it will ice up and you'll pop out core-plugs
how wrong you are!
Hitting the wheel with a hammer tends to free the hand brake off
i found that this morning, i parked it up after work last night and with it being stood over night the handbrake was solid! hit the wheel and we were off again :-)
What you actually got a hammer to the rubber or?
how wrong you are!
Well you are just gay. :lol:
*runs*
I used to tap the alloy a few times with rubber mallet.
Last time didnt have one to hand so slammed it into reverse and slammed my foot on the gas. would not reccommend that really.
Pretty much wehat I used to do when I was pulling cars out of compounds where they'd been sat with the handbrake yanked on hard for 6 months. Plant it and dump the clutch normally works.
My other favourite trick on cars with spokey alloys was put the wheelbrace against the rear caliper/drum and idiot it with the jack.
might get higher.....
handbrake off, chock the wheel. restart every once in a while.
