6n Engine Power
I am newly back as a Polo owner (used to own a Mk2 a long time ago).
I am suprised to find how poor the power made is by the engines. I have a 1.4 6n (on an N plate), just to commute to work. It is meant to put out 75bhp or so. I also own a Pug 106, 1400 and the power is 100bhp standard (on a K Plate). Adding a decent filter/tubular manifold and a decent exhaust saw over 110bhp.
So why is the Polo so low to start with, and why is it so difficult to get anymore out of it? they must have been in competition for sales at the time?
  • Replies 10
  • Views 1.3k
To be honest, i think the Polo's are just more restricted as standard, and the pug engines are more highly strung.
I think the end result of tuning would amount to the same power, i know which i'd rather be driving... but the phase 1 106's are renound for ripping your faces off, especially with a valver lump.
the 6ns 1.4 8v engines produce 60bhp or there abouts :)
59 Bhp actually :(
OK, no one else post how little the power is - that is depressingly low!
My 106 has now had a "new" engine, so it is about 145bhp, and 16v. I didn't think that was much, but now it apparently is!
Still the polo is much better spec'd and much more comfortable!
Let's not forget people, the 6N 1.4 8v wasn't meant to be a ripper - there's more power to be extracted from these engines should you choose to do so.
If you want a quick (ish) standard car buy a Lupo/Polo GTi.
Also, this valver'd 106, what mods has it got done?
Absolutely. I wasn't after a ripper this time, as I need it to get me to work and home again!
What can be done to them?
As for the pug, it is a bit of a long list...
Stripped out.
Plexiglass windows
Group N Billie suspension, on custom front springs and lowered disc rear beam.
206 GTi Front brakes, group N discs, and race pads.
Rebuilt Saxo 1.6 16v engine, with performance chip (proper one), cams etc. K and N Induction kit
3/4 cage
Race seat and harness
Quick shift and solid rods for gear change.
All bushes polybush'd.
As a result it is quick without trying to kill me, and handles superbly!
If you wanted a 100bhp 1.4 Polo you could have had one, the 16v made that. The 1.4 8v was only ever aimed at the middle aged commuter market, it has relitivly small valves and not a lot of lift to give power low down in the rev range for easy driving, like a lot of VWs I think its also over geared to bring down the cruising RPM. So they were aimed at a totaly different market to the 100bhp 106.
I don't think its worth trying to get more power out of the 1.4 8v on a cost/benifit basis. Just drop a GTi lump in as they can make some nice power without too much work.
Edited by Depresion
Stripped out.
Plexiglass windows
3/4 cage
Well the 6N is a great car for what you need, common faults are gearbox and stem seals, but easy cheap fix if you are mechanically minded.
As for the valver, they're fantastic cars, i will never slate one, GTi/VTS can't be credited enough in my books, my mates got a bright yellow GTi, group N cams, pug sport exhaust, manifold etc... no word of a lie gives Focus ST's and the like a run for their money.
Only one that comes close to it is the valver'd rallye shell rocking around LOL and that's practically the same car.
Fun, cheap, fast...
You are being a bit unfair towards the Polo here.
Your comparing a 106 XSI with the TU3 engine to a basic shopping trolley Polo.
If you want to compare the 106 XSI with a Polo of the same era your looking at the Polo GT and G40, their power outputs maybe a little more to your liking.
Of the newer 6n we only got one 'quick' model over here which was the 1.4 16v 100bhp version, but they aren't really a match for the 106GTI of that era.
Thing is in my eyes the Polo has never been made to be the fastest little car out there. There will always be a quicker French car or the like but once they are all thrashed out and knackered the Polo should still be going strong.
The un-fairness is not really intended.
I wasn't after a rocket ship, just suprised that it was so much down on power compared to the equivilent Pug.
I chose this route as I need proper reliability (not highly strung power), comfort and spec.
Although it will be a struggle, the engine will remain standard as will all the other parts!
