Latest bike carb'd AEE rolling road graph...
Hi guys, as some of you may know i have been having a bit of a mare with my car for a while.
Well it went into 'Hi Tech' in Cradeley Heath on Wednesday morning for another tinker and it came back with the following power graph (9bhp up on previous run)...
They have advanced the timing which seems to have given more power through the range. The final run made 138bhp and 120lb/ft which i am happy with.
HOWEVER, the cam is STILL not performing right, i have to rev off the clock to see a real hard pull, and it is too 'peaky' for the engine. The plan is to raise compression as i have been told sometimes you need to do this to get the best from high lift cams. In addition to this, i may look at running a different cam, maybe a phase 1 or 2 instead of phase 3 (tarmac rally).
I'd like to thank all the people that have given their opinions on the problems i have experienced, in particular mikey, redroller, yeha, cymro and sanderbeer.
Now hanging up the car keys and having a bit of a rest from the tuning until i have some more cash to fund head skimming and a different cam. At the moment i'm just enjoying going to local cruises/meets and people asking about the car and taking photographs etc.
Pic of the car at the last meet:
283906_10150241632184024_628254023_73090
  • Replies 43
  • Views 3.8k
wow that it tremendous(sp?)
what engine mods have you done to achieve this?
I'm jealous right now
good figures man,car looks cool too :thumbsup:
For starters the engines been rebuilt (where it counts most).
Yamaha R6 bike carbs with custom inlet manifold.
Mk2 ignition (original Mk4 ECU removed).
Stage 1 dynojet kit.
Four branch exhaust manifold and custom decatted system (fully heat wrapped).
Ported and flowed head.
Newman phase 3 camshaft.
Vernier pulley.
Malpassi fuel injection to carb regulator.
Malpassi filter king regulator.
Mocal oil cooler and braided lines with thermo sandwich plate.
Lightened and balanced flywheel (4.8kg down from 6.3kg).
Think that's about it?
Edited by leeds_finest
this is about how much power i want from my AEE with my 600 carbs. can you tell us what you have done to the engine and management? my engine will be in a mk3 coupe on the 8P gearbox. i am thinking though of messing with the gearbox and thinking of trying the 5th out of the 1.6 and 4th out of a 1.4. i am unsure yet to what cogs to use yet though. any advice??
Thanks mate, it now has the silly front number plate removed that is pictured there, and the motorbike size plate fitted in the recess next to the oil cooler (hence velcro strips).
Hi mate.
Engine spec above.
Management completely removed. Currently ECU is in a box in my garden shed i think? Wiring and plug lie dorment under the scuttle panel wrapped/taped up in a carrier bag. A few wires that did go via the ECU need chopping out and connecting back up but with a Haynes it's not too hard.
As for gearbox, i swapped from the EQY to the EQW which uses GT ratios with the 4.06 diff. Only problem is, as expected, motorway and 50mph above cruising the car sits at high revs, but for thrash, which is what the cars built for now, it's better.
wicked
Carrier bags degrade over time.
Wrapped up some engine bits. Came back a few years later to find a pile of bits covered in flaky white bits.
What's the spec on your head?
What was done and do you have any flow data?
Hi mate.
Engine spec above.
the engine loom is part of the car loom isnt it? my coupe there separate so I'm sorted with that.
completly forgot about the diff, if I'm using the 8p box would it be better to use the GT diff? diff isnt something i have though about tbh. and i dont no box codes for the 6N, are the the standard 1.6 and 1.4? if your bothered about the motorway speeds change the 5th. but as for the high revving at 70 i no what u mean, 1.3 on 1l 5 speed and at 70 I'm doing 4K! as you said though the round town blasts etc are sweet, pull away from most things at the traffic light GP.
wicked
Ok i'll bare that in mind thanks. I hadn't planned on leaving it for that long, plus the car covers about 2-3k per year, not really exposed to the elements, in a unit under a cover.
Standard valves, 272 degree cam, vernier pulley, rebuilt with new stem seals, new valve guides and the ports have been ground out and smoothed both sides.
No flow data i'm afraid, all work carried out by CHD in Bromsgrove, pretty good rep to be fair..
Hi mate.
Engine spec above.
I can't really comment too much on boxes mate as i don't really know a lot.
All i can say is that the EQY is a 1.6 box and the final drive wasn't very good for acceleration, but i could get 120mph in fourth with fifth gear still to go.
The EQW is from a late 1 litre 6N, with GT ratios and a decnt final drive.
I actually find 1st gear a bit pants, but top of second and third it gets shifting pretty well.
1l box? on an AEE? i spoke to a bloke wi a corsa 1.6 SRI that had a 1l box on and i was like, wtf, does it not shread the box?? my car shifts well in 2nd and 3rd too, but i prefer to be in 2nd than 3rd. my first sucks too. is there anyone i can speak to about gearboxes etc? mikey may no, or varnish? will drop them both a pm and find out.
this is absolutely great mate hats off to you. and the car looks ace you got a build thread for this or any more pictures of the engine bay ect?
Nice figure for an AEE, i do think it can be a better engine with the right cam, even if it means a few bhp less.
Tbh someone correct me if i'm wrong, but i imagine the box internals are all the same strength, they wouldn't normally make a stronger box unless the model was seriously more powerful and the jump from AER to AEE isn't that big, so i imagine the strength of the boxes are equal - both being absolutely pants. My old box blew up, and if this does the same, i'll try and have it rebuilt instead of just fitting another second hand box because they're all weak.
'Yeha' knows a fair bit about boxes tbf, try him too.
Thanks mate, there was a build thread but not updated in ages. More pics on facebook if you want to add me leeds.finest@hotmail.co.uk
Totally agree mikey, this is why the car went in actually, i had planned on sacrificing a few ponies to bring the cam kick further down the revs and i have come to realise after 3 setups, 117bhp, 129bhp and 138bhp that the cam is in fact wrong for my engine. Just goes to show every setup is different as mine behaves nothing like Sanderbeers.
Plan is to up compression and change cam and hopefully it'll behave how i want it to then.
The cam really isnt that lairy though realistically, I think you need to look at inlet runner length, diameter, the headwork and exhaust diameter as much as the cam duration. I wouldn't increase compression and get a lower duration, one or the other really, a higher compression ratio would complement the cam and give an all round increase. A 63HP gain is doing very well! Lightened flywheel also isn't going to help at low rpm's either.
I had 40mm carbs, 1.75" short tubes (2mm wall) and 2.25" exhaust on an AFH on carbs on stock cams, and that didn't come on power till about 5k rpm and fully screamed all the way to 8k after that, doing it again, I would have put smaller everything on.
^^ Yep, the most torquey/grunty 1.6 I've ever ran had a full 1.3 carb exhaust on it.
But whilst smaller exhausts are better for low rpm,they restrict further up. Same with porting the inlet etc.
Its always a compromise. So you shape an engine for how you want it to run. That's why I've always recommended tuning the long stroke 1600 small block for torque,because its nature for torque is already there (unlike a 205 1.6 GTi or MK1 Golf 1.6 GTi for example,which are large headed short stroke engines).
To be fair though, look at the graph theres 120lb\ft at 3k rpm, 20 ish up on stock at stock peak torque rpm, and 30 hp more than stock where it used to make peak power rising to 68...
Stock figures are 75 PS (55 kW; 74 hp) @4800 rpm 100 lb·ft @2800–3600 rpm AEE 1996–2000
how come it has a bit of a drop at 5000 rpm? is that due to the cam ect? someone fill me in pleasee :) nice one on the power though thats crazy!
Just wondering...how ''safe'' is this kinda setup as a daily driver? Like 15000 miles a year?
Is raising the compression gonna hurt the pistons and rods?
What kind of cam would people recommend...I'm guessing not too wild due to the low down power sacrifices and steady road use...around a 264 newman?
Definately be following your progress mate!
Phil, that pic is with your coilies fitted btw if it's any use at all :)
Tbh guys, i just threw together a setup that i thought would be fairly worthy. I bought my cam a LONG time ago off BIG4424 and didn't really do a lot of research into it before now.
I agree with Phil in that a 272 isn't a particularly lairy cam at all, the chap at Newman also said this, but for some reason the kick does come really high up the revs and it doesn't make sense. Forget the graph for a moment as it is mis-leading, the real belt comes around 7k, i can confirm this from driving the car, and it is as clear cut as a VTEC crossover - one minute it's 8 valve growl, the next minute it's VTEC scream, so i know this is where the cam is pulling, and you can feel it through the car too.
I can't comment on different size exhaust systems, inlet systems, exhaust ports and inlet ports. I whole heartedly agree that there could be more to be had by using a different approach, i just don't fancy pulling apart what has taken ALOT of blood, sweat and tears to put together.
I can however make judgement on the flywheel. I drove the car before and after and i think lightening the fly by just 1.5kg has the best of both worlds really, hasn't compromised low down driveability and didn't even have to adjust the idle after fitting it, ticks over fine, but does seem to climb through the revs that little bit quicker... but again, i take on what phil said, you would generally sacrifice low end torque for top end power when throwing a lighter one on.
If i can give an opinion on the way the engine behaves, i would IMAGINE that affecting things such as inlet and exhaust would have a difference on the way the car drives, but i think something drastic is needed to correct the way it is currently.
I love the car to bits, i just think it's STILL not at it's full potential. I spoke to my friend with a DC5 integra and he runs skunk2 cams. He told me that the advice from the bloke that built his DC5 engine was that compression would need to be raised in order to get the best out of his cams, sanderbeers has also been raised... are we seeing a pattern here? £45 quid at Cylinder Head Developments says we shall see what happens, although for the short term i can't be arsed (if i'm honest).
Mikey, if you have a second, could you post the link to the starter motor thread? As i may need a different starter with raised compression?
Phil, was your last post positive or negative? :) i couldn't tell whether you were praising or knocking the figures lol.
I don't feel a flat spot when driving the car so it's minor, but yes it could be because of the cam or a descrepency in the fuel setup of the carbs i reckon.
The other lad with a similar setup says his has taken 40,000km of abuse and still goes strong.
Mines only been on the road a few thousand miles but touch wood i haven't had any issues, it never runs hot even when i'm thrashing it, and i've been on journeys upto Durham and back, round trip of 400 miles from the Midlands and it seems fine.
I imagine upping compression will put more stress on everything, especially rods, but we'll just have to see.
nice one man. up the 8vs
Thanks bud :)
Agreed - 8v carb growl FTW.
Need a video of the beast ;)
Before worrying about cams or upping the compression etc, I'd look at your ignition curve. It's all good stuff swapping around different bolt-on bits, but you'll never really know what the combination of parts you've got can do 'til you get the ignition optimised too - fuelling's only half the story.
