Latest bike carb'd AEE rolling road graph...
Need a video of the beast ;)
I'll try at some point mate, its a strange one, off the mark it aint great, but high up in second and through the gears it goes well.
Before worrying about cams or upping the compression etc, I'd look at your ignition curve. It's all good stuff swapping around different bolt-on bits, but you'll never really know what the combination of parts you've got can do 'til you get the ignition optimised too - fuelling's only half the story.
Ok so how do i check this and how do i know if its right or wrong?
  • Replies 43
  • Views 3.8k
There is no right or wrong as such. Ignition is down to the management used, in your case the mk2 Polo setup, old and not the greatest but works fine, did they have a play with the ignition timing when RR'ing it?
Would get the best from it with a Megajolt type mappable ignition setup. Wasn't knocking it, you've got a good all round increase, fair enough your saying you have to rev it to get it to sing, but you have a fair amount more power than stock lower down the rpm range. Cam - I was getting at is peak powers at 6500 rpm, doesn't seem to be that bad. Could be down to the extra lift the 272 has, but I reckon its down to the combination of the whole setup.
The cheap thing to do yourself would be to play with the base timing on the dizzy and see what affect that has - but doing that will only advance or retard the entire ignition curve, which won't help you if the curve is the wrong shape for the engine.
Somewhere like Aldon Automotive that specialises in older stuff will be able to re-profile the ignition curve for you with some dyno time so that you know it's truely optimised. Alternatively, you could buy a mappable ignition system, and have a go at tweaking your ignition curve yourself - so that if/when you make more changes to the engine, you can optimise it again without spending any more cash.
Yes the ignition timing was altered as far as i know.
6,500 doesn't sound that bad, but as i said, when driving the car it's relatively flat through the revs and then a sudden switch comes at around 7-7.5k... pretty useless on said engine.
So does the megajolt eliminate the dizzy? And how much am i talking?
Sounds like mappable ignition may be the way to go, we'll have to see, thanks for the advice.
Maybe it is the ignition lacking through the revs, i'm unsure to be honest, it just feels as though the cams wrong.
Might be worth asking Aldon how much a session for an ignition curve re-profile costs? If you're in Walsall they're only 10-15 miles away from you.
Megajolt with most of the bits you need is just over £300 from trigger-wheels.com, but there are cheaper ways if you use scrappy parts and build bits yourself. I'd be tempted to spend a little more and get Megasquirt instead though, as it leaves you the option to run fuel injection at a later date.
If it were me, I'd mark your dizzy up so you know how it's timed at the moment, and have a play yourself. If you can swing the timing so that it's great at 4000-6000rpm but pinks at 7000rpm, you know that a different ignition curve will let you have the great high rpm and mid-range performance you're after and that it's not the cam giving the "V-TEC" feel. If it makes no difference, then you know not to bother with that 'til you've played with other things first.
The only reason I mention ignition timing, is that it's so often overlooked. Your ignition curve is for a strangled 1.3 lump, not a free breathing 1.6, so I think it's worth a look. Granted it's a different engine, but at 6psi of boost my K03'd G40 only made 100bhp the first time on the dyno - an extra 8-10° of advance across the rev range got that to 133bhp which was what I expected from it.
I think that may be the next step then.
Megajolt sounds good, but where does it get pulse from if the dizzy is removed and blanked over?
Crank sensor ;) More accurate than a 4 lug dizzy too.
I thought it may have been crank sensor, but does that mean the block needs drilling and tapping? Not feeling that idea...
Yeah just a ring on pulley & fab yourself a bracket for the sensor, then there's the ECU and coilpack for it
Sounds like hard work :(
Your the one who put motorbike carbs on your car :lol:
Lol yes and that was enough grief :lol:
So do they run the original dizzy to get an idea of the engine RPM so they can program the mega jolt in the first place?
Could you not run a dizzy from a nz engine mk3 coupe?
Mpi ignition curve with vac advance iirc...
i beleive you can use the mpi mk3 ignition and ecu sustem and all you need to do is unplug the injectors? i dont remember anything about it, just remember seeing someone run 600's on a mk3 GT and he just did this and it ran fine? may not work as well as you may hope tho.
but he is already using the vac advancing dizzy from the mk2 right?
How about Ford ESC ignition module?
Found in MK3 fiesta's with the 1.1 engine.
It uses a coil pack, but advances the ignition from vacuum signal.
It uses a fixed map.
I'm pretty sure it doesn't even use a crank trigger.
It wouldn't be hard to build on this and add the extra parts needed to go to full 3D with the megajolt.
So if i decided to go megajolt, could i just weld the toothed wheel onto my auxillary belt pulley?
Yes indeed!
Yes indeed!
Cheers, because i couldn't bolt it to the front of the pulley, because it's dished inwards, and that pulley bolts to the actual crank pulley itself.
Weld should do the trick then.
I'm pretty sure this is the route i shall go next, along with different cam and raised compression.
