Rubbery bit inside door card.......
How do I get this off? It's the bit behind the door card. I have taken the round black bits off but there's some white circular bits under them that won't come off, how do I do it? I need to put the door on my car and connect the window mech etc up. Also when I put it back on what glue should I use? :?
  • Views 636
Any chance you can get a picture of what your talking about? My mind isn't working well this late and can't think of any rubbery bit behind the door card :lol:
The draught/water shield. I think he means the glue around the edge of the sheet. I just gently pull the plastic and the glue lets it go then you just press the plastic back into the glue once your done.
