front suspension clattering when driving
the 2ps in the struts seemed to work for me aswell
my suspension is now worth 8p more ! haha ,
  • Replies 48
  • Views 3k
i took suspension out today and replaced the top mounts , to be honest , they werent actually that bad , i also dropped some 2ps down the strut for good luck too ! thanks yeti !! and slapped it all back together , used some round exhaust rubbers too , one on each side like so .
to be honest , if you just use the rubbers you guys with the problem should notice a massive difference , and as you will know , only will need to remove that top nut ,
rides and handles so much nicer now too ! no more clattering :D
RESULT !!
i dont understand how this would work unless coating it with grease as the cup has to spin freely so if you jam it up with a rubber mount then it will hinder your steering surely?
RESULT !!
it still moves , its rubber , it has movement , steering is so much better than before too , your not jamming it with a rubber mount , its adding a support between the cup and chassie . i like it , :D
That's actually a really good idea.
Because even with brand new parts the cup bangs up and down which isn't gonna be doing anything any good.
I might put a dab of grease on them rubbers though just to give it some lubrication...
yeah i may well do that dude , shapow :D
Banging noise could also be caused by the steering arm rubbing/hitting the brake servo when you go over bumps. Very common problems when Polos are taken down 60mm or more
i dont have a brake servo !!
And mines lowered around 80mm at the front and its still quite far away.
80mm !! woooo thats low ! so you get scared when you see speed bumps !?
My subframe does :lol:
hahahaha :lol: ,gonna be getting one for mine , they aint got no stage 2 subframes in at the minute though , so gotta wait, wasnt sure whether the stage 3 would be a little overkill though ?
Would be for road use mate, especially for the money.
yeah i thought so too , gotta wait like 8-10 weeks now though , as they wont have no more in until then , the peeps at polo performance that is anyways , dont think any one else does em >?
I'm really sorry for the stupid question.. what is '2ps'?
I have the same problem. I just finished mounting a new set of Bilstein VNE-4501 and BNW-2848 along with some pedders lowering springs and found that mine also makes a horrible clatter when u go through potholes and general uneven road, and also the steering makes some clunking / scraping sort of noise now too, I'm wondering if as i have read, that its too low, but its hardly lower than stock at all, you would have to have a standard height and my car alongside each other to notice it.
How do you tell if the top mounts are worn out? do they increase they're 'cup' depth as they are stretched longer and longer?
Only reason why i ask is that i sent it for a wheel alignment today and they said that they could not do it for the fact that the strut does not sit properly on its mounts, but thats when they had it in the air, and with such a gap with no pressure on the strut tower holding it into its mount, that was always going to happen surely? Doesn't the weight of the car and the rubber mount under the strut tower ensure that the strut is centrally located when bearing weight?
I'm confused...
a 2 pence coin
a 2 pence coin
:lol:
a 2 pence coin
okay so it is what it thought it would mean, but how do you put 2 coins down a strut? where would they go? (sorry for the seemingly silly question) I'm guessing our australian 20c coin would do roughly the same thing
Edited by pontiff
s'all about the 1ps and 2ps!
you have to take the shock insert out of the strut and put the 2p at the bottom, then refit the shock insert.
you can also fill the gaps with fluid
forgive me, after looking at the posted pics some more, I'm talking about a 6n1, which appears to look different than the ones here (I'm new to this polo world, so forgive the stupidity)
i think my problem is referred to by the pic in an old thread
http://www.clubpolo.co.uk/forum/index.php?showtopic=141625
where the top mount has compressed which is creating that void when lowered etc, ill grab a new one from the local parts specialists and see how i get on in the first instance, then a exhaust hanger mount will be the next port of call...
sorry to hijack this somewhat...
normal tv service will resume shortly
Would this be the same on 6n2s?
same philosophy applies i guess, i had a chat to my specialist mechanic friend and he said that its a common VW issue, golfs and what not suffer the same ill
Top mount issue or insert problem? Just to clarify only mk's 1-3 have shock inserts. 6n onwards has shock struts as one unit.
attached are 2 top mount pics, the silver ones are okay, the red ones are cactus, see how the silver ones are recessed which when fitted with their top caps, would be a snug fit.. the red ones protrude
How would you fix 6n2s then.
