key recognition problem ?
Hi
Having some issues with starting my N reg Polo , turning over and starting but rev's then falling and engine cutting off ,have been advised by RAC that there may be a problem with key recognition ? Have tried original and spare key.
Anyone advise how to resolve this ? and rough £££ ?
much appreciated.......
cheers
  • Views 876
starting for a second and then cutting out ?
sounds like the immobiliser.
does it need a visit to a Garage to resolve ?
cheers
Very strange to lose the coding.
two options.
1. recode through vagcom, takes minutes.
2. buy a matching key, transponder box, ecu.
This may sound silly but while turning the key and once the car starts try and lift it upwards slightly. If the car works fine and then cuts out when you let go of it then it is the ignitions switch on the bottom of the key barrel.
two options.
many thanks
will try and thanks
