6n2 steering wheel
how do u get the air bag out so i can bolt the wheel into my 6n ? and do i need to use anything from the 6n for it to function fully i.e horn and the air bag ? thanx for the help . Dave
  • Views 921
There are two holes on the back of the wheel (a right pain to get at with the wheel on the car) inside them are clips that hold the bag inplace. Use somthing like an allen key to flick at the clips as you can't see what you are doing and you don't want to damadge the insides for obvious reasons.
Removing
WARNING
Disconnect battery earth strap before working on electrical system.
– Turn steering wheel -1- until horizontal spokes are vertical. Pull out steering column completely and press down to lowest position.
– Insert a screwdriver, about 5 mm wide and angled to a length of 55 mm, in hole on back of steering wheel hub.
– Turn screwdriver 90°, circlip -2- is pressed off lug in steering wheel hub and airbag unit is released on this side.
– Turn steering wheel back 180° and release second retaining hook on opposite side.
– Grip airbag unit by horizontal spokes and lever out of vertical anchorage.
WARNING
Electrostatic discharges may result in unintentional triggering of airbag. Therefore, the mechanic must electrostatically discharge him/herself before disconnecting the igniter and earth wires. This can be done by briefly touching the body or striker plate of the door.
– Pull connectors off airbag unit.
Thanx guys thats great . Dave
