A/c Condenser
Hi there, just had my 2003 polo diagnosed as having a leaky A/C condenser, I have been quoted best part of £350 for a new one from VW, but can get an after market one for about £90.
Can anyone shead some light on how easy it is to replace one? it look to me like you have to remove the front bumper, unbolt and swap old for new. Put bumper back and then off to have it regassed?
Any help would be much appreicated, even if it just how to remove the bumper. Cheer
Many thanks in advance, Simmo
  • Views 3.3k
Front bumper
Removing and installing bumper cover
‒ Remove radiator grille => Page 66-9.
‒ Pull covers -13- for headlight washer system off bumper cover and unclip.
‒ Release cover -66-2.
‒ Remove bolts -6- .
‒ Unclip outer air guide grilles -10-.
‒ Remove bolts -2- and -12-. Pull cover off guides -5- (left and right-hand side).
‒ Separate connection of temperature sensor.
Trim
Removing and installing radiator grille
1) Radiator grille ◆ Material: ASA
2) Locking tab
3) Bolt ◆ Qty. 2
4) Retaining pin
5) Centre fixing point
6) VW emblem ◆ Clipped into radiator grille
Removing
‒ Remove Torx screws -3- from grille.
‒ Release locking hook -2- with a screwdriver.
‒ Pull retaining pins -4- and centre fixing point -5- from lock carrier and remove grille upwards.
Installing
‒ Align grille on centre fixing point -5-, press lower retaining pins -4- into bumper cover and clip in upper section.
‒ Screw Torx screws -3- into grille
All vehicles
– Disconnect hose for headlight washer system at T-piece.
– Remove bonnet lock → Chapter.
– Disconnect Bowden cable -3- at lock and separate electrical connections.
– Disconnect connections at headlight housings.
– Secure radiator and condenser in engine compartment → Air conditioning system; Rep. Gr.87
– Unscrew bolts -2, 7 and 8-.
– Carefully remove lock carrier forwards.
Servicing refrigerant circuit, which may only be performed at workshops with specially trained personnel (specialist repair workshop for air conditioning systems)
Removing and installing condenser
Warning!
Always disconnect the battery earth strap before working on the electrical system.
Notes:
◆ Obtain radio anti-theft coding before disconnecting the battery.
◆ Check vehicle equipment (radio, clock, electric windows) as per Workshop Manual and/or Owner's Manual when reconnecting the battery.
◆ Refrigerant must be evacuated with Service station V.A.G 1885 first.
◆ The previously used service stations can still be used =>Binder Volkswagen Workshop Equipment.
◆ All components of the refrigerant circuit which have been opened must be sealed with suitable plugs to prevent the ingress of humidity/moisture.
Perform following work first:
‒ Extract refrigerant with Service station V.A.G 1885.
Note:
Discharging refrigerant into the atmosphere is an offence.
‒ Remove bumper.
=> General body repairs, exterior; Repair group 63; Front bumper; Assembly overview.
‒ Remove refrigerant pipes/hoses on condenser and seal.
1) Lock carrier ◆ Removing: => General body repairs, exterior; Repair group 50; Body front; Removing lock carrier.
2) Radiator
3) Bolts ◆ 8 Nm ◆ Qty. 4
4) Condenser ◆ With fluid reservoir
Nige8021,
Many many thanks, little bit more work than I initially expected. But its only nuts and bolts when all is said and done!
Thanks again, might give it a bash and see how i get on.
