Missing chunk out the front of 6n
Hey all, can you tell me what body part I would need to purchase to have this sorted? And how much generally are they? Cheers
  • Views 974
you'll be able to get it from a scrap yard, in the right colour for about £10
It's called a grille rail and to get it off;
remove the indicators by undoing the torx bolt at the top, then they slide out.
This will reveal the securing screws for the grille rail (only one at each side)
Next, unclip the grille, using a small flat head screw driver, push down on the centre of the clips.
The whole assembly will come out. Takes no more than 5 minutes usually.
17 6N0853661C trim lower
/ 6N0853661C GRU primed
Listed @ 51.6 Euros!! try the "cars breaking" section in the classifieds on this site, or a scap yard, early ones are metal later ones are plastic, if you can't get the same colour easy to respray with a rattle can
