Roboffs Flash Red 1.0 L
The rear fog doesn't use a relay either, but you definitely don't need to add any relays if you fit the wire from the fusebox to the headlight switch and then modify the headlight loom for the fog lights
  • Replies 58
  • Views 9.5k
  • Bit of an update, i have FINALLY managed to get another centre cap for my RZ's ;D biggest pain in the arse ever! Cause they're the Corrado G60 ones and not BMW ones, the Rado boys dont want t
  • Got abit more work done on the little Polo :) Noticed the door and back arch where getting abit scabby, few small bits all over, biggest was about 5cm x 5cm, but wanted to get it sorted sooner rather
Got the cambelt done on the Polo today seeing as it got to 100k, not to hard of a job, just abit of a pain taking all the alternator pulley off and stuff.
Before i go into the fogs, big thanks to Nige and Dixy for all the answers to my stupid questions about them. Double thanks to Dixy who sent me the wire for the switch/fusebox for nothing! (it got lost in the post somewhere but thats another issue :-( ) managed to make one up, just with a few more through connectors than id have liked.
Managed to get the wiring for the fogs done, ran out of daylight so couldnt get them fitted.
Gave them abit of yellow tint film for that JDM Yo feel :)
28152810-38C7-4884-8D7F-6091856CF3C9_zps
Dropped the fuse box, which was alot harder than i thought it would be.
28DE591A-2A32-4EA9-80EC-82AE8599714B_zps
The wires from the fuse box to the headlight plug are there, but not from the switch down to the fuse box. So pulled the plug for the lights up front and added the new wire.
33E40B09-E16A-4472-A28E-8B15CB6C4D0F_zps
Added the new switch with two stage pull out, think its off an ibiza as it lights up red.
6AC50AC0-35F3-4646-9C29-AECD12779A36_zps
Then took the head light plug to bits and added the two wires for the fogs, only two cables so not too bad.
7D5986F5-B483-4C4D-B823-4F936FCE9676_zps
Hooked them up to test them out and ta daa!
C9061BE6-EA59-4B04-B7A2-F7883B79FF11_zps
Still need to fit them in the bumper, but shall save that for another day :)
Let us know what you think!
Tom
Spent this morning fitting my fogs, managed to do it without taking the bumper off, but if i was gonna do it again id deffinately take it off.
1A64DC19-8B3C-4BA5-800E-EA857C75518C_zps
Fogtastic :)
E3F14D14-F355-4779-A5DF-2FA487BAE1D5_zps
All back together
BFE25D44-0B04-475C-A0A6-3657FB58BC9F_zps
B03119EF-C4A3-4761-B1F3-A76BD90FD97C_zps
Only problem was the wires where a tiny bit to short to run them the way i wanted, so i need to lengthen them a bit.
Also managed to get a glovebox lock, so its not held up with a cable tie anymore :)
151E9202-B0DE-4A0F-8444-2D63AD24712A_zps
Also, does anyone know if you can get these from anywhere? its the little cap that goes on top of the float switch on the brake fluid res. I had a look on all the usual places but no joy
77DCD9F7-F561-4C8E-A193-11360D518DD2_zps
Thats about it, let us know what you think :)
Tom
Edited by roboff
Fogs look really good mate
Cheers pal :smile:
  • 5 weeks later...
Great flash red polo! Really jealous of your painting skills! I have never tried painting but always wanted to.
I have a flash red one myself, this has given me a little inspiration! Thanks dude :)
The fogs look good. :)
Out of interest, did you use anything specific to polish your rocker cover?
Cheers mate :)
Nice one :) err no i dont think so, just used some wet and dry then autosol or whatever its called. It didnt stay shiny for long though, i haven't bothered again haha
Wow. This polo has came along very nicely i must say.
Just makes me want to get a compressor even more now.
