Urgent: refitting mk3 rear seatbelts
I took the rear seatbelts out of my G40 a while back as I've not had a back seat. I need to give some mates a lift tomorrow and have refitted the rear bench but am having trouble with the seatbelts.
The inertia reel seems to be locked, and I can't pull the belt out to feed it to the mounting points. Is there some kind of release mechanism I've not seen?
  • Views 721
have you bolted the reel to the car first? usualy puts it at the right angle to allow you to jiggle it out
+1
it will only unreel when at the right angle IMO
Sorted, cheers guys. It does unreel when you hold it as if it was bolted to the car :)
