Spraying Wheels
So I just bought some BBS RZ's of a friend for £70 already shot blasted :) So they are ready to paint. I just need to know a few things..
Firstly how much paint will I need? I'm on a budget so I'm just going to get Halfrauds stuff, I know it's not the best, but I'm hoping if I take my time doing it, I should get a half decent finish. I've been told I will need 2 cans of primer, 2 cans of colour, and 2 cans of laquer as a minimum. Will this be enough? Or will I need more colour? I do want the best finish I can with this paint, and I want it to last as long as possible.
Whats the best method of doing it? Ie, how long to leave to dry between coats, do I sand with fine grit paper between coats? Or just between primer and colour? etc etc. And I've never used laquer before, anything I need to know? Any other little tips from people with experience?
Cheers.
  • Replies 9
  • Views 1k
Best off starting with self etch/acid etch primer on alloys ;)
As well as normal primer or instead of? Whats the difference between the two? And what benefits will I get from using it?
etch prime all the bare alloy...this bites in and helps it stick well
then straight one with some high build primer ..do 3 coats and see how it looks , the idea is for the primer to smooth over any rough surfaces , once its stood a a few days wet sand with 800 until its smooth , if its not smooth more high build and sand again until its dead smooth and flat ..this is the most important bit smooth primer = good finish
light coats of colour , no need to hoof it on , keep going until its all covered and even looking ..do not sand
after 10 mins on with the clear coat ...id suggest you the 2k rattle cans off ebay as its much more durable and should look nicer , go for 2-3 coats of clear
I would suggest going to a paint shop to get the paint, rather than Halfords, as although slightly more expensive, i tend to find better colours but more importantly much better paint (deeper paint shine and also longer lasting) and it seems to be easier to get a decent result.
Thanks for the replies everyone :) I'm just going to get the two different primers, do that today, then by next week when the primer is hard and I have some more money I can buy better paint.
Cheeeers :)
have you added up what the cans will cost , i bet its not far off having somewhere spary or powder coat em , id say you will need close to 1 can of each per wheel
Not really thought of that. I don't have a clue how much that would cost. I've already bought the primer now so I'm going to carry on. Updates to come in a few days..
