MK2 trim and features.
I've just found myself a 20,000 mile 1989 CL 1.3 MK2 bready! so pleased. Must not be too many of that low mileage knocking around.
The interior is fantastic bar a few things are a little loose
I tried this on my mk3.. how do I get the window regulator handles apart to tighten the screw that holds it there, without destroying the handle? I used a screwdriver last time and scratched it to shit just to get it off.
also I have fixed door mirrors with a little toggle to angle the glass. They dont respond awfully well. how do they work? any good way of restoring them?
cant beleive VW did anything with the interior.. this is so much better looking than my MK3!
  • Replies 13
  • Views 1.6k
that is low!
mine's at about 107000 i think, and a year younger than yours =P...
shes beautiful aswell. no dings of any size.. little scratches.. great paintwork REDICULOUSly tidy interior.
wondering how she ranks mileage wise..
anyone know about the questions? thanks
I dont even want to drive it now :?
cars are to be driven enjoy it. when i got rid of my mk2 it was on nearly 170k.
I agree. especially volkswagens are for driving!
Same mileage as mine now! 20, 750 ish! Wish I could say my paint was immaculate but my interior is basically new though.
Edited by MattLoaf
The answer is a screwdriver. perhaps put a small bit of electrical tape to protect the plastic from the sharp edges of the the screwdriver.
As for the remote door mirrors take the black knob off and the rubber boot and then you should see the mech. The Mech consists of 4 braided cables. With some wd40 or similar add the little red straw you get with it and spray it down the little cable pipes wiggle the adjusters and do it again continue doing all the cables and wiggling until it frees up
awesome, thanks.. now that I think about it I have the ones that I damaged as a template for where to stick the screwdriver(s) to minimise damage.
nice. The paintwork on mine is certainly not immaculate.. tho with a polish it would look it when u stand back.. there are some scratch lines which appear only to reach the base coat so may be able to rub out.. however no dings to speak of.
Mine is super flat on the roof and rear end, the front is covered in stone chips and the passenger side has three long key marks that go right down to the metal =[ Link.
Edited by MattLoaf
the paint on the roof of mine is a little dull.. been thinking about t-cut etc but being cautious as I know what can happen with that stuff!
I'm thinking mine must be in outstanding condition.
..did a compression test on the engine last night. 13.1 BAR on EVERY pot! hahaha. yeeeeeess.
I was wondering wether I could divert this thread to underbody.. or if there are legnthy previous posts, wether someone could direct me to them as I have no idea how to use the search effectively.
The underbody of the car is also fantastic, but a few areas like the twist beam at the back that have mild surface furr. was wondering what is the best way of stopping further rust in these areas.
scrape back the sealer until you reach clean steel , then dremel /drill with a wire wheel on the rust until its all shiney
then coat with epoxy mastic http://rust.co.uk/epoxy-mastic.cfm
