fitting cobra buckets to a 6n, help!
On Monday I'm going to acquire some very very cheap blue cobra bucket seats, hardly ever used. all perfect :)
however the downside is I have no clue where to even start on attaching polo subframes to them, I'm not sure exactly what model the cobra's are,
but i do have a spare pair of complete seats so I guess I can use the subframes off them?
any pictures or help is brilliant :) cheers
  • Views 667
I think most cobra seats have side mounted subframes in two pieces, The main part with the runners which bolts to the floor, then seperate bits that bolt to the sides of the seat and then to the subframe :/ Not 100% though...
Edited by Elliott250990
or cut the foam off your old seats and cut the seat pan off keeping the subframes, then cut two strips of steal about 30mm wide and 5mm thick for them to fit left to right on your subframes, before you weld the strips to the frames bolt them to your buckets and place them on your frames in the car before you weld so you get them in the right place or you will be cutting them back off lol ,,,,once you have marked where the strips go take them out of your car and off your buckets or you will set your seats on fire like i did:D weld them on :) then bolt them back on :)
