mk2f gt interior in mk2
just bought afull gt interior for my mk2 breadvan and cant get the front door cards to fit everything else is fine, main problem i have is the toggle to adjust wing mirrors has a bracket that is too large for new door card do i need mk2f bracket or is there a way around it. also all the plastic trim bits leave large gaps :S anyone have any advice so i dont have to either dye my original door cards
  • Replies 8
Not looking good lol
Doors are the same so fit shouldn't be an issue. You may need to swap the brackets but not sure as my ETKA is down. Usual issue is where they meet the dashboard when closed.
thanks and haven't got that for yet :S
New issue is door card hitting dash when door closed any way around this?
bump
Soak the area of the door card where it hits the dash with water and then close the door..
its should mould it into shape...
I've never tried it but thats what I've heard other people do.
Thats correct. Fitted a full Mark3 interior in a Mark2 saloon a few years ago. Just saoked the front edges of the front doorcards in water, closed the doors and forgot about it for a few days.
The only other things you will need are the inteior door fittings from a Mark3.
going to try that now thanks for help :D
