Iscariot's Mk3 GT
Could do, but tried it with my old car and couldn't really find a suitable place to run them without drilling 3 holes in the bulkhead/ bootfloor which I'm not overly keen on doing for rust reasons!
By the way, do you know if there are two types of mk1 golf outer cv joint? I have Gti hubs and have heard that the CV joints are Gti specific.
  • Replies 318
  • Views 31.5k
In terms of spline?
I cant see it making any odds unless its the spline fitment. It may be for other reasons relating to the driveshafts (i.e. strength/fitment to the shafts, differing diameter of the shafts).
I have just changed my hubs on the mk1. I'll try a polo driveshaft in the mk1 hub (which I'm pretty sure will fit). Then i'll measure the hub cartridge bearing ID on the golf hub and check it against a polo one, so that if there was a difference in the splines, but the bearings were the same, you could have my hubs or fit the polo hubs, which I'm pretty certain will retro-fit the golf bearings/housings
Yeah in terms of spline! I know the polo CV's won't fit the golf hubs as the splines are different unfortunately :-(
Ahh nah it's cool man don't worry about doing that, I just need to know if the mk1 Gti cv joints are different to the mk1 1.1/1.3/1.6 cv joints in terms of spline?
i dont think they are mate I'm pretty sure the outer cv is the same I'm about to buy some new outer cv's this weekend and I'm buying just mk1 golf ones the outer spline wont be any different I'm sure the only thing i think may be different is the bit where the driveshaft goes into on the cv but i dont know why this would be different.
My mate has some 1.6 mk1 driveshafts and jims 1.8 scirrocco driveshafts are about, i can try them in my small block golf hubs. I wont be up my unit till the weekend, i'll have a butchers then for you!
After doing abit of research I've come to the conclusion they are all the same mate :thumbsup:
I'd say so too, tried jims 1.8 rocco driveshafts in a pair of 1.1/1.3 hubs tonight and they fitted fine. As long as you can get the fiiting to the drivshaft to work then you should be fine as regards the outer spline.
Tried a polo shaft in the golf hub and was suprised how much smaller the splines were in diameter.
Cheers for the help lads, much appreciated! Ahh it's okay i can pick em up for around a tenner each so it's gravy :-)
This car is gonna be siiiikh
15's are too big :( (RM's)
You still gonna machine up steering arms for the coilies or you just gonna chop some struts?
Yeah man gonna machine some up! The other ones are too bulky and will sacrifice lows cos i wont have as many threads available.
Well, this happened earlier :lol:
376384_181363265287946_100002428201247_3
piece of shit
Ah shit!
Sweet, look forward to seeing them, maybe interested in a set if you fancy making a few sets up for a bit of cash ;)
Blew it up, threw a rod through the crankcase!
How the funk?
Damage! Were you giving it death? What plans now?
Hahahah, I joke. It's only the hall sender! :lol:
Just about to go scrappy to get a new one an it'll be soouuund!
Was going to say you must have been giving it a real dry bumming if you managed that on a 3F :lol:
Is that a challenge? :lol:
It's had a bit of a dodgy idle/ shit mpg/ down on power for a while so i thought it was the hall sender on it's way out - did a 400 mile trip in it the other day which seemed to have finished it off!
Maybe :-p
I love 3F's.
Clutch cable went on mine last night as I pulled in at home. Pulled up outside home, went to put it in reverse to neaten it up and snapooo! Never been proud of a car breaking down until then, well chuffed :-)
:lol: This made me laugh more than the actual issue :p
Hahah I'm a student, cant be going to VW and forking out over a hundred quid for a dizzy or 50 quid for a new sensor!
@Demolover yeah man they have a knack of breaking down so conveniently! It could've broken down in the middle of dorset two days ago, but it decided it would break down on my mates drive, i almost gave it a pat and said 'cheers' haha.
I don't even have a timing light here, could be interesting getting it setup :lol:
Did mine by ear on the coupe.. Never let me down :lol:
man i could never do it just by ear.... I'm so anal about things like timing haha
Its not hard to set up the ignition timing, get some advancement on there too!
Yeeah i know, I'm just a bit anal and would rather do it with a timing light to get it bang on!
Digifant controls the advance though, adjusting the base setting will do nowt!
think you guys forget the wanky procedure for properly setting up a digifant controlled engine! cant just do it on idle and hope for the best
Edited by Iscariot
