MK2 (with a mk4 engine) Rev counter options?
As title. I have a MK2 bready.. running a mk4 16v lump (with bike carbs!)
Basically, i cant do without a rev counter and cant seem to find an OEM one.
If i buy a sort of small simple cheap one from ebay, to mount somewhere on the dash, how hard will it be to get working? I'm not very good at that sort of thing...
Any help please?
  • Replies 8
  • Views 2.1k
wire the gauge into the power circuit, normal wires on the back are Power +, Ground, Signal, Dimmer/light (or option to change between day and night modes) and Signal.
Then for the rev signal you can run a cable from the gauge's signal fitting to the negative side of the coil (assuming you have a round type).
If the coil has a red/black striped cable then splice into that for the signal at a suitable point (if the cable is there then it should also be on the plug that goes into the back of the clocks)
Hope that helps,
Ceri
Edited by Cymro
real easy to wire in mate just feeds off the negative off the coil and also just needs an ignition live and an earth you get instructions with them too
Cant see why not, TBH thats a pretty nice looking gauge, cheap too.
i agree! Cant decide weather to go for a small simple one, and put it in the gap where the headgasket goes.. or tucked in, in with the other gauges. Or to get a BIG one like that and bolt in onto the dash where the little speaker cover is in the centre. that sounds cool. but I'm worried about pulling it off without it looking shit....
Thoughts?
you gonna run a rev counter in your combustion chamber? dude your immense!!!
to be honest a gauge like that would look really out of place in a mk2 polo. Personally I would just keep a look out for a original one. They do come up every now and then.
to late... the deed is done! lol.
Gotta try something new! if it dont work, it dont work!
