Dave's 16v Open Air - Scrapped
Sounds good mate! Look forward to seeing this progress.
Cheers boyo! ;d
Some goodies arrived the other day, got around to fitting them on Saturday!
(not the best pictures, using my shitty phone camera :oops: )
393934_10151070412420430_763145429_22370
Surprisingly that took me 2 hours. 1 Bolt rounded off and I only had a file, a screw driver and a hammer to try and get it out with :disgust: anyway, got it off in the end and cleaned up the slam panel a bit (after picture was taken)
Fortunately I managed to source a left foglight surround off of Pepe :thumbsup: Cleaned that up and gave it a fresh coat of paint. So currently the front end is looking like this:
407874_10151080901910430_763145429_22419
Hoping to get some better pictures soon!
Tempted to order some yellow tint for the fog lights, however i'm unsure atm and also skint so that will have to wait! :lol:
Also my lower passenger glovebox that sits under the airbag from Germany has turned up!
Haven't got around to fitting it yet, however I reckon it's going to take some modifying to fit..
Oh and hoping to strip out the carpet this week and seal up the floorpan as i've got soaking driver footwell :( It was coming in through the door so that will get sealed up too!
Dave
Edited by daveb142
  • Replies 307
  • Views 38.2k
Another Small update... (if anyone's actually looking :lol: ):
Popped down to VW today to pick up the parts I needed to fix my lock and also some new bungs for the floorpan.
Also my new headlight switch arrived!
Seat Ibiza headlight switch that has the option for front and back foglights and also headlight adjustment... I did have a switch that could operate the fogs, however it made my headlights all wonky as it didn't have the electronic adjustment and was an older style switch!
Anyway, got it for a tenner off of ebay ;)
However I did forget that Seat's had red led backlights...
Not the best picture but you can see lol.
I actually kind of like the red.
Will update next when I have sealed the floorpan and will hopefully have better quality pictures!
Oh and Merry Christmas! :D
Dave
I'm looking! :D haha.
That switch, how does the headlight adjustment bit work? Do you have to have udrated standard headlights??
Haha I know you'd be Tommy ;)
And I have electronic headlight adjuster style headlights as standard on my polo..think its 97 or 98+ that have them buddy!
Ahh i see! I want some now. Haha thanks man
Looking good man!
Front looks alot neater.
Haha I'm sure you can pick a set up along with any other loom etc you need from a scrappy..might be a bitch to fit/wire in though!
Looking good man!
Cheers man :) All I want now is the body work to be sorted! The bonnet is doing my head in >.< aha
Edited by daveb142
So I got around to stripping out the carpet today;
Just before the carpet was removed (removing that dc sticker too...):
Removed the carpet, what I didn't realise was that the rear footwell was worse than the front!
Instant stream of water!
That's actually all water there ^
I thought that there was a bung missing in the floorpan there, however there isnt :/ the bung that's missing is right under the arch so it cant get through to the inside (directly).
I'm guessing, that when I noticed the roof leak and also a leak down past the bonnet release cable, was that it had done this for a while before i noticed it. The fact the drivers door had been leaking didn't help this matter :/
The top layer of floor is a tiny bit fooked mind, is this normal btw / is the circle in the floorpan meant to be there? I pushed down on a corner and it went down to another layer of white floorpan beneath it?
So the carpet and drivers side sound deadening is currently stripped out, going to clean the whole area tomorrow and shove a bung in the hole under by the arch to see if this helps.
I've put my drivers seat back in for now, however going to leave everything out to dry and also to see if I can spot any leaks in the next week or so! :lol:
Will be giving the carpet a good valeting too!
On a side note, fixed my drivers door lock :) picking up the parts to fix my passengers lock tomorrow!
Dave
Edited by daveb142
Looks like some bodge welding to avoid MOT failure.. haha
Haha yeahh, however it's fine on the bottom? :s
Oh also took some pictures on my brothers camera the other day.
Shows how much I've neglected the exterior in the past month or two :(
379814_10151095671785006_582995005_21729
395549_10151095672310006_582995005_21729
:oops:
393943_10151095672795006_582995005_21729
Stone chipped enough?
392319_10151095673190006_582995005_21729
Foglights onnn
393880_10151095673785006_582995005_21729
397588_10151095674230006_582995005_21729
395175_10151095674365006_582995005_21729
402331_10151095673910006_582995005_21729
397564_10151095671895006_582995005_21729
Really want to get the body work seen to and my BBS' back on :(
Fixed the passenger side door lock :)
For once can finally unlock/lock from both doors! :lol:
Also, torn between my 14" bbs RZ's without centre's....or some 15" bbs RA's that have come up for sale close...what you guys reckon? ;/
Imo i would go for the RZ's mate
Yeahhh, i'm undecided atm...need to find some pics of the RA's fitted to a 6n!
Boring ?
Better ?
8-)
Yeah fair shout! haha.. Might go to the 15"s of the RZ's!
Also..the bottom pic..where did you get that picture? haha..I know the guy who owns that, lives down In Plymouth ;)
Edited by daveb142
The 15's of the rz are much better than the ra's ;)
Edited by rozza92
Found it on Google, But here's his build,
http://www.swdubs.co.uk/forum/viewtopic.ph...36&start=15
Ah right haha forgot he had a build thread on there! Cheers bud, Yeah the RZ's do look much smarter, was tempted to look at the RA's as the guy lives stupidly close to me ;/
Yeahh man I think I'll just stick with my RZ's for now, might look into getting the 15" versions at some point but just need to get mine finished and get some tyres!
Edited by daveb142
Yib Yib!
Carpet and sound deadening now fully dried out!
Will be putting them back in at somepoint, going to attempt to valet the carpet first before putting it back in :)
Carpet put away properly :ninja:
Also got bored the other evening whilst leaving town late:
I really need to stop using my phone camera...
Will actually sort the overfuelling and more important issues out this month!
Also my handbrake plate inside the car came un-riveted so that needs welding down :(
Dave
Edited by daveb142
It all comes together very nicely! Keep up the good work ;) .
Thanks man :)
I've picked up a new thermostat, housing and seal from VW this week, all I need now is the inlet gaskets and VAC hosing and I can set about fitting all the parts!
Hopefully this will sort the overfuelling problem, Gonna be seriously pissed if it makes no difference...wouldn't surprise me though :lol:
Oh I've also given my car a nice wash today! First time I've cleaned it since October :oops:
I have now got all the parts together to hopefully stop the overfuelling and sticky thermostat :)
Getting my engine tray removed tomorrow and then hopefully cracking on with fitting the parts on Saturday
Fitting new thermostat, seal and housing, Inlet manifold Gaskets, Thrust/MAF Sensor and also replacing all the VAC hosing. Also need to check the charge across the battery due to it cutting out the other night!
Anyway, met up with Coreymk3 the other night and took some photo's 8-)
Credits to Corey for the photo's!
Should be getting 2 new tyres and the BBS' refurbed this month too.
Dave.
Not really any updates, just a few pictures taken from the SW-Dubs meet at exeter and budleigh salterton. 220 cars were counted at Exeter Services! :lol:
My car looks gash, needs more lows and new wheels. Also want to do something with the front end as I'm not feeling the debadged grille anymore or clear indicators.
Also i've been reallllly slack and STILL not fitted the thrust sensor, inlet gaskets or new thermostat :lol:
Anyway, only a few snaps of my car whilst there
Link to the meet pictures thread
There will be actual updates to come in the next coming weeks btw! ;)
Dave
