Noobie.
Hi all,
Noobie to this forum, i've just bought myself a Mk2 Bread Van 1.0 ltr, i guess the following qestions will have been asked before.
I've been told by me "Olds" that i can't mess with the car ... little do they know :lol:
So my plan is simples, leave it looking as standard as i can - So can you answer the following for me.
* iIm after wider steel wheels either 13 or 14 inch - what will fit and not stand out when the "Olds" look at it i still want to run the wheel trims.
* Lowering kits i see some on the site so may go for one of them but i'd rather lower it slightly and use uprated shocks as well so it still looks standard but rides and handles better.
* Anti roll bars front and rear- can i fit other from other Polo modles say GTor G40's
* Cam and carb - i see "Newman" cams are thr ones to go for - which one would you guys suggest - i'd like to fit a bigger carb and still retain the air box, any suggestions.
* Any thougts on flowing the head ?
* Exhaust - can i fit a manifold from a 1.3 or GT would i see any improvement.
If i do all the above engine mod's do you think 65/70 HP is reachable ?
I'm training as a car mechanic so i don't mind getting my hands dirty so i'll have a go at anything but as mentioned a need to do this on the sly so i need to keep it looking as standard as i can.
D.
Lots of questions from the noobie i know - sorry but i have itchy fingers and i'm deperate to get started.
  • Replies 10
So you want new wheels but want to keep the wheel-trims on? (Edit: More grip, herp derp.) Get some pictures of this beast up.
Edit: In before this thread goes crazy because the username is kinda' feminine.
Edited by MattLoaf
for all intense and purposes, GT engines look exactly the same as your 1 litre. sly enough? :-)
edit: is it like 'darling' off blackadder?
Edited by arron0909
Welcome :) I'm new too :p
Mk2 golfs have 13" steelies that are wider than the standard baked bean tins
Could always fit a 4branch, but make a heat shield fit it and hide it ;)
welcome, theres alot of answers and options for everything you want to do.
for the steels, have you got the later wheel trims? that would only fit 13"? if thats the case, then mk3 gt steels would be your best bet, exactly the same design, but wider. You could get wider tyres on the current rims though.
Then basically all 4x100 vag steels will fit, mk1/2 golfs and most mk3 golfs have that stud pattern. 13" and 14"
6n polo steels could be an option, 13"
lowering kits: take a look at phil j's range, 40/40 is probably what you're looking for.
anti roll bars: best bet once lowered are the nylon bushes etc, phil j does them too. A gt rear beam would sort the back end out.
as for the engine, you could change to a coupe s engine, would be less work i'd have thought, plus they look the same.
gt engines also look the same, depends what you'd use to feed it though.
you can then upgrade the brakes with vw type 2 calipers
Hope that helps.
Edited by VolksKid83
Hope that helps.
Sorry its off topic, but is their a thread on this ? Id like to rmsee more on this one :)
oh hello darling.
I hope you look exactly like captain darling (blackadder)
Hope that helps.
don't think theres a thread, but you need the calipers and discs most definately. Not sure about difference between pads.
The discs and calipers are a straight swap and fit onto the existing carriers, its the setup that g40's used.
Gt engines don't look the same as 1l engines due to having mpi, different airbox design and a different rocker cover.
A 1.3 from a mk2 would be your best stealth option, as they do look the same, except for the 5spd box you'll have. You could add a gt cam too, considered the best OEM cam for polos
To be honest, of it's your first car, leave it standard and get some experience on the roads. Then if your parents allow it, get a second car to modify in the mean time
Hope that helps.
G40 pads are sided (one has a long pad the other a short one) and are thinner (15mm instead of 17mm), but G40 pads will fit non G40 callipers (some of the VW1's require the thinner G40 Item or the calliper wont fit back on), the whole point of using the VW11 callipers is to run vented discs.
A decent set of normal discs and pads are up to the job.
