Steering wheel help
Hi just wondering what it is I need to remove the standard steering wheel off a 1993 Polo Coupe and is there any easy step by step guide to doing this?
  • Views 905
et urself a haines manual man its all in there
pull off the horn cover ..should yank off by hand
then undo the center nut...its around 24mm or so , leave it on the last few threads and give the wheel a tug , once its popped lose remove the nut
Would I need a boss kit to fit an aftermarket steering wheel?
yes
Right cheers mate
