Cable location - help!
I've just pretty much completed an engine swap in my 16v 6n, all has gone pretty well i just cant seem to find where this cable belongs?!
Its part of the fuel injector and throttle body loom if that helps, image below.
Cheers for any help!
  • Views 1.4k
Can you see the wire colours? might be able to ident from that, could be the "knock" sensor? mounted below the inlet manifold
One wire is blue and the other is a white/grey colour. Cant seem to see any connections below the inlet?
Cheers for the reply.
Those colours would point to it being the Knock sensor or possibly the EGR? see the pic.
Checking components
Wire routing engine wiring loom
1) Oil pressure switch (F1)
2) Securing clip
3) Exhaust gas recirculation valve (N18)1)
4) Coolant temperature sender (G62) ◆ Blue ◆ With coolant temperature gauge sender (G2)
5) Ignition transformer (N152)
6) Hall sender (G40)
7) Injectors (N30...N33)
8) Intake manifold pressure sender (G71) with intake air temperature sender (G42)
9) 3 pin connector ◆ Grey for engine speed sender (G28)
10) Cable routing ◆ For engine speed sender (G28)
11) Cable guide ◆ Clipped onto fuel rail
12) Knock sensor 1 (G61)
13) Securing clip ◆ Secured to cylinder block
14) Engine speed sender (G28)
15) Throttle valve control part (J338)
16) Engine wiring harness
17) Connector ◆ Black, 4 pin ◆ For ignition transformer (N152)
Cheers for the diagram mate, il take the inlet of tomorrow and hopefuly get it connected up then!
Dont suppose you would know if the knock sensor or EGR would majorly effect the engines performance? since its lacking servere power at the minute..
Cheers once again.
Cheers once again.
Without the knock sensor the ECU might be running the engine in a degraded setting hence lackof power, the EGR is part of the emmisions control and has limited effect
I hope it is! because its definitely not how it should be.
Cheers for all the help, il get it sorted tomorrow.
