Height Adjusting Seats?
Any of the 6N2 range have height ajusting seats?
Mines an S and the seats dont.
I sit far to high for my liking, feel like I'm sitting on the car rather than in it!!
Shawn
Shawn
Looking at some info online I noticed the 6n2 and the 6n share the same platform... The group A3.
I know the Mk3 golf and the 6n Polo also share that same platform, and the seats in that are interchangable. The front ones are a straight swap but the back ones need the mounting points swapped out.
You might be able to use Mk3 Golf seats in your 6n2. I'm sure someone will confirm this or correct me if I'm wrong.
If thats the case then I know the Mk3 Golf GTi front seats are height adjustable because I had them in my Mk3 Golf and now I've got them in my 6n Polo.
Hope this is some help to you.
you most certainly can use mk3 golf seats, the 6n2 is just a facelift of the 6n but with better quality steel and basically revised most of the problems the 6n. I said most not all the issues. my 6n2 16v has tilting height adjustment?
Thanks for that you two.
I would put another 6n2 interior in if i found one with adjustable seats.
Guess that the SE and GTI ones adjust?
Mines an S
Shawn :-)
