New and need advice
I'm looking into getting myself a mk3 polo ideally a breadvan
just wondering are there any common faults and bits to look out for when buying one?
and what are the 1.0 and 1.3 engines like?
I'm after a standard one so i can have a play and make it abit ratty as i am bored of my mk1 arosa 1.7sdi and always wanted a breadvan
thanks
  • Views 760
1.3 is good, especially if you manage to get the rare mulitple point injection engine but the single point injection is just as good, 1.0 is good too they are nippy for the engie size/weight
about things to check, rust on arches, rust of filler neck of the fuel tank, water leaks in sunroof if has one, waterleaks into footwell, there are more and i'm sure people will add to the list
ebays a good place to find standard ones e.g. Squareback
cheers I've seen alot with rust etc
seen quite a few nice ones on here in the for sale bit but all miles away :( dont mind going like 100 miles tops or somewhere easy to get to by train but needs to be decent one
problem is i dont want to spend loads on one as i know i can get cheap standard ones all over the place
all i wanna do is drop it on some nice wheels and then keep it clean until gets rust then rat it
but it needs to be good driving as need it to go to and from uni every day in september
Check for gearbox whines aswell mate
