Mesh grille fitment... any tips?
Hi all, I got a mesh grille for my 6N.
Anyone fitted one?
Its supposed to replace the slatted area of the original grille, leaving the framework and the but under the headlights in place.
The slatted area is fitted with a few clips that pop out, but the slatted grille I have doesnt seem to line up with any mounting points except the bottom one.
I am in contact with the company i bought it off of because there were no fixing screws included which there was meant to be, but they haven't fitted one so they are not sure how it mounts.
I was wondering if theres maybe a bracket missing or something along with the mounting screws that they forgot to include.
The only way I can see of mounting it the way it is, is if i drill two holes in the front frame just where the holes on the top of the grille are, but surely this cant be the way of fitting it... If nothing else it would slightly compromise the overall strength of that part of the frame.
Heres the one I've got
http://www.veedubmachine.co.uk/index.php?m...products_id=140
  • Views 630
It says it comes with nuts and washers. Have a look to see if there are any bolts at the top of your front panel or just under your slam panel. I think you should take a pic of your car with your grill removed that way we can have a look for you. Does look to just bolt to the slam panel though.
Yea from the grille it looks like it just clips in at the bottom and screws on through the two top holes but theres no where for it to screw into as far as I can tell.
Ill get a pic up as soon as i can and show you what I mean.
