9n respray
Basiclly I have a project 9n, once I've got the car looking how I want the only parts that won't needed repainting will be the roof and rear doors. Should I just get it painted bit by bit ie fron bumper n bonnet, then boot n back bumper then front doors and sideskirts. Or just drive around looking like a pleb with a fully primered car and save for a full respray. Thanks
Edited by deanwt
  • Replies 8
Any ideas guys
Going to just get it done bit by bit n hope colour match is good
I would just get the whole lot done together, will be cheaper in one lot then small parts at a time and also you can guarantee the paint colour will be 100%
You would be pretty gutted if the colour didnt quite match!
After spending over 600 quid on new bumpers n that i pro would be lol, will prep it myself and roll around with a grey car lol
Primer is porous and will trap dirt, grease etc as you drive around. As a result, the finish is likely to be substandard when compared to one not driven around in primer. Personally I'd save up, prep and then take it to the body shop immediately
Thanks for the advice, I have a few small dents and my rear vw badge to fill in. Should I just leave the bodyfiller showing or primer these bits to protect the filler or is it not realy required to primer over bodyfiller to protect it?
EDIT as i cant spell lmao
Edited by deanwt
Primer is semi porus, it will absorb water, but not overly quickly, i drove my 6n for a week in high build primer!
Bare body filler though, that will soak up water, then when the car is painted and baked, it will evaporate, leaving holes in the wet/wet base coat and lacquer, any filler should be smoothed out with p320 then primed.
Any more questions, shoot me a PM
Cheers bud, if i get any trouble with it will drop u a line.
