breadvan Inner rear wheel arch rot
Hi ...just decided to repair my breadvan after 2 years and now discovered driverside rear arch rotten right through.does anyone know if there is a replacment panel for this problem,or if not whats the best way to repair this...i can weld but not great...I'm sorry if this has been covered b4 ,i tried to find a thread but must of missed it.....cheers stu......
  • Views 744
Check out my thread (search for too far gone) I'm going to attempt to weld it up at some point, there is no panel available that I know of so some sheet metal will need shaping.
cheers dude .I'm going to try this weekend ....
SAme actually if the weather is ok. All I can suggest is thick steel 2.5mm should do it, lots of prep work and replace a large area as the rust goes further than you can see.
