First Practical Classic
Hi Comrades
This is my first "Practical classic", I plan to use it daily and do it up as I go. I have never owned a polo before, I have just picked this up for £100. It looks in really good condition and was used daily up until it broke down last month, I went to look at it, gave the guy scrap value and drove it home. It had a flat battery so I had to jump it off of my boss' 4x4. The tax ran out end July and MOT is just out. I have listed the work that needs doing to get it up and running below so if anyone has any comments or has experienced similair problems, please post a I appreciate any advice.
The first issue is a starting issue. It turns and turns and turns but does not fire, (Battery replaced) the spark is big though! so I am going to chnage the inline fuel filter first off and if this does not work, I my have the fuel system presure tested. When it fires up it runs really smoothly and starts first time for the rest of the day.
When I drive it, it makes a deep vibrating sound that seems to come from the bottom front area, I checked the wheel bearings and there is a very small amount of movement in the N/S/F bearing so I plan to replace this. Experience tells me that the vibrating noise is more of a vibrating than a grinding so I am going to check the engine mounts for perished rubber.
I am going to replace the shocks all round, any tips to improve handling? Lowered etc. Also i don't like plastic hub caps so may look for some early golf alloys or such like.
Hopefully I can sort out the starting problem and then take it in for an MOT see what it fails on.
I am guessing this is a mk3?
  • Replies 12
  • Views 1.6k
good bargain!!
yes it's a mk3, or a mk2f as they are sometimes known.
you sound pretty clued up already about cars so good luck sorting those problems!
I have a -Bottom- strut brace on mine (connects the bottom parts of the suspension towers. That made a significant difference to the roll, which I found the worst part of the handling.
mk2 facelft that is fella but most people call them mk3's
looks like a good base to work with
as for improving the handling theres a few routes to go down all depending on £££££££
if price is not option get on ebay and ppp and order yourself inner and outter tca polybushes (on ebay look for strongflex)
then go to ppp (polo proformance) and get yourself some g-ladder arb blocks and a stage 2 subframe :)
as for the back ream beam bushes (g-ladder) although aloy of people prefer standard
streathen the rear beam
and you can also use a rover 200/400 arb for the rear
but like i say its all ££££££££
but hey enjoy your dub :) and welcome to the forum
Edited by 01mlacey
you have a mk3 breadvan as its most commonly known there are quite a few people that have them on here your best bet would be to look at others cars as regards to lowering and wheels because I've heard that the rear arches scrub on a fair few
as to your questions
check the hall sender on the dizzy as this can be a huge pain in the arse if thats whats causing it (its the black thing on the dizzy best getting a new one if thats at fault) other then that take the fuel hose off the inlet this will show wether fuel is getting through or not may just be air getting in the system somewhere
the vibrating could be your anti roll bar bushes worn out a warped brake disk or a cv joint on its way out failing them somethings come loose and needs reattaching
if you want to uprate your suspension there are a few options dependent on your budget the cheapest being phil j on here if you have money there are other kits available and coilovers are available but you will pay a fair bit for them
other then that looks a nice motor hope you enjoy it
matt
Thanks for all the replys.
MK 3 bread van it is, I like it!
Anyway, had a fiddle today and get this. I noticed the fuel was low so I put a gallon of fresh in and it stated first turn, was really pleased. Turned it off stated again no probs. Got excited. 2 hours later turn turn turn turn nothing. Weird.
I thought about taking the fuel pipe off and checking flow as mentioned here so yeah , may try that tomorrow, also I'm thinking of a fresh set of plugs. Thats all I had time to do today.
Thanks for the tips on the handling, I am hoping the MOT will pick up any worn bushes etc, I may get the tester to road test it for me too, to here the noise and see what it sounds like to a trained ear.
Cheers Wurzel
Can you get a pic of this for me?
Check the fuel pump relays located in the scuttle tray next to the ECU. I had similar issues when my fuel pump relay packed up. It took an age to start whilst the relay was deciding whether or not to work.
You can get them new from VW for around £8, but they aren't waterproofed like the original ones, as they have been superceded so many times they now share a part number with the current Audi A4, so would require sealing with silicone sealant around the base to prevent moisture getting at the internals. The originals have the whole base covered in silicone for this reason.
Failing that, a trip to the scrappy is your best bet :wink:.
Thanks for that Info, I think I might try that next because I fitted a new set of plugs, a new fuel filter and it turned and turned. The batery ran down I charged it and it turned and turned. I decided to go back to the kitchen table for a cuppa and a read of the haynes manual and about an hour later i decided to check that fuel was getting through as advised by a previous post. I thought i'd see if the battery needed charging and turned the key, it fired up before it even turned once !! I ran it for 10 minutes, turn it off, started first time, ran for 10 minutes off, started, off, started, off, started. This seems to me like it has to be a relay or something as if it were fuel surely it wouldn't be intermittant
I'll keep you posted.
Wurz
Car started first time this morning, really horible damp morning too! I have ordered a new fuel pump relay from VW. 10.89+p&p
As I mentioned earlier on, don't forget to seal the base up on the relay so the damp and drizzle doesnt get in to it :-).
Looks like you've gotten a little gem their :)
Thanks for the advice about the fuel pump relay.... I sealed it up with silicone and since fitting it, it has started everytime. I thought I'd take it for an MOT to see how much it would cost to get through and it failed on only bold tyres and an advisory for real wheel bearing! - well chuffed. I was telling a bloke at work about it and he said he had a roofrack for a polo in his shed - tidy!
So - good polo day today!!
New tyres coming to garage tommorow, so by Friday the 'Breadvan' will be my daily run about.
Next Job, rear wheel bearings.
