Polo Mk4 Harness Fitting
I've just bought 2 sparco 3 point harness's and want to fit them to my 02 Polo, but I'm not sure how. Can i run it down the back of seat, because i want my back seats. Also how significant do the joints have to be to secure the harness?
Any advice would be brill
  • Views 611
I wouldnt advise fitting harnesses with the rear seats in, its a ball ache. I fitted mine yesterday but i took my rear seats out and stripped the car also :) 3 point also, The way i did it was take the front seat out so that you can get to the bolt the standard seatbelt clips to and bolt one of the straps there, bolt the other side nearest the door so the bolt that holds the bar in place for the original seatbelt, and bolt the shoulder strap(s) to the rear clip mounts under the rear seats. If you keep your rear seats in you can have harnesses, but...You wont be able to have people in the back.
This was in my 6n1 though, might be different in a 6n2 :s
Helpful?
Edited by Elliott250990
