VR6 Turbo
Well I've bought the adapters now so ill see for my self if they fit.
Ebay picture lol
  • Replies 1k
  • Views 114.1k
Braided Polo To Porsche Brake Hoses, Just the discs required now.
Just a heads up on these brakes.. I've had some brembo's fitted to my 6n and to say fitment is a nightmare is an understatement
Judging by the pics you have, the brackets you have bought fit the ibiza brembos which has the same fitment as the 6n so should bolt to your car fine
not sure if your calipers are the same as the ibiza ones tho
now when you fit the discs, you cant use the ibiza 305mmx28mm (which were desinged to work with the brembos) as the disc will hit your ball joint
it is aparently not safe to use g60 280x22mm discs due to their thickness.. or lack of
and there arent any other off the shelf 4x100 discs you can use as far as I'm aware
I've had a company make some 2 piece discs made with the same dimensions as the ibiza discs, but with some more offset to clear the balljoints
at which point my caliper was in the wrong location so i had my brackets remade to space out the caliper
which is a bad idea coz its hard enough to find wheels to clear the brembos and spacing them further makes this even more difficult
using the ibiza discs will mean u need 16's minimum and the wheels will need to be of a certain spoke design or heavily spaced
so in all fairness it may be better to go for some 4 pot willwodds which can be used with g60 discs with which u can run 15's i believe... not 100% sure on that tho
but i really wanted brembos on my car which is why i went through the nightmare of making it fit 8-)
u may find an easier way of making it fit.... but i couldnt find another solution
Oh dear, this sounds like its going to be fun ha. Really appreciate all your information mate. Could i ask where you got the discs made up and how much they were please. Cheers
Just thought on. Can you use them ball joint adapter things?
Edited by polovr6man
nah no good... i had a right ballache with my first set of wilwoods
had to send them back a couple of times to get things right, and now its a right pain to find some wheels that'll fit -_-
I dont think those ball joint extenders will work tbh
I went with hispec brakes although i think AP brakes will do the same thing but a bit more expensive
Think it was £120 per bespoke centre bell.. you will need two of these.. these never need replacing
the actual disc is about £75-100 per disc and you can pick how big u want the disc
the brackets were 120ish for the pair
and the bolts to connect the disc to the centre bell was about £20 i think... they are strech bolts and need replacing at every disc change
the above prices are + VAT... they wouldnt budge on their prices, not even for cash :-(
also you aparently get some kind of better braking performance with it being a 2-piece disc... not sure why tho
so to get the setup working cost me £550ish + the cost of the calipers which i got fairly cheap
something to keep in mind is that servicing the brakes (2 rotors + bolts) will be around £260
I've attached a pic of the two different brackets... you can see the hole i had moved to to push the caliper out
if u decide to go with a smaller disc you will need to move the caliper closer to the centre of the hub to ensure better claping on the disc which would mean the other two holes (the two you cant see in the pic) need moving... if that doesnt make sense i can get u another pic which makes that easier to understand
if u have the capability.. or know someone else who does... then you can buy the plain bells relatively cheaply and do the work yourself (£100 for the pair i think)
if not the prices i paid for the bespoke work is above
Edited by no1naz
Okay i may have to go down that route, The calipers, adapters and brake hoses already stand me at £580 so another £500 would be a joke ha. I emailed the company who i got the adapters off and they told me to use mk2 golf hubs and ball joints and i won't have a problem with the 305mm discs. Not entirely sure though.
i dunno... i cant see that working
if u try it and it works then happy days
but theres a chance u buy more stuff and it doesnt work and you'll be even more out of pocket
i asked around on clublupo and i got one answer about someones setup
they spaced their disc using brake shims... deffo didnt sound safe
if u want an easy install speak to josh about his willwood setup
and sell your parts to someone with a golf/ibiza/corrado as the fitment will be perfect for them
if not be prepared to dig deep into your pockets :lol:
Okay sorry for all the questions but I'm still trying to get my head round this ha, is it the thickness (28mm) thats the main problem with hitting the ball joint then and not the length (305mm)?? or is it infact the offset of the ibiza disc? I just can't get my head around why it will fit the mk2 golf perfect but not the polo lol.
no1naz says sell them to a golf owner then surely if you can somehow fit mk2 golf hub setup surely it should then work as it would on the golfs? therefore much cheaper and happy days
Take a look at this pic
this is what happens when you fit the ibiza 305mm disc
now this is what the bracket looks like on the car.. now if u refer to my previous pic of the two brackets, you'll understand how my new bracket has shifted the caliper further out
i dont have any more pics of the 305mm ibiza disc but if u look at my brake disc... the outer rotor (braking surface) is sitting a few mm's behind the centre mounting bell
whereas on the ibiza, the outer part of the disc sits a further 10mm into the car (which is what i meant by offset)
the reason why g60's arent safe is because there 6mm thinner so when your discs and pads wear away, there is that chance that the pads will be forced out too far
this is because there built for thicker discs
come to think of it i think i remember comparing the ibiza discs with the standard 6n2 gti discs and I'm pretty sure the ibiza ones sat a fair bit deeper into the car
not 100% sure tho... it was a while ago
i dont know why they seem to work on a mk2 golf, mk3 ibiza but not a 6n polo
all i know it didnt work on my car :lol:
i think josh originally had a willwood setup sent to him that was built for a mk2 golf and that hit his ball joint too, might be worth checking his build thread
Okay mate, i really do appreciate all the pics and info. I can see now why the ball joint extender wouldn't work. I think i'm going to have to do a lot more research before i commit to buying some discs then lol. Ill have a look at josh's thread now see if i can find anything to further my knowledge on the brakes ha.
yeah the 305mm discs are hard to come by
only ones i could really find were on ebay for about £100
but if you are not in any rush then yeah research into it
i had a time restraint on me at the time so i just had everything made custom
but the caliper now sticks out a fair bit
so even with prosche wheels and adapters (25mm spacing i think) the wheels still dont fit so I've had them spaced a further 10mm to make them fit
i may have over-spaced the caliper when i had the setup made but i didnt want to under-space it and repay to have everything made again
so be careful before you go down the same route as me
Edited by no1naz
Haha, okay i'm not in a rush to get it finished so ill do some more research ha. Ye I've seen the discs on ebay for £99.99 drilled and grooved. I'm wanting to get it finished for the spring gti fest so wish me luck lol
The problem is the angle the ball joint goes into the hubs
I had some mk2 golf hubs and the angle was different they sat vertical unlike them polo hubs that have the bottom angled out
If I were you I would get hold of some cheap mk2 golf hubs and try them mate I'm sure you can pick them up cheap enough from eBay or go scrapyard hunting
Aha cheers mate, so the on the mk2 golfs the ball joint goes into the hub at 12 o clock instead of 10 o clock thereby not interfering with the disc? Will a mk2 golf hub bolt straight onto my 1998 polo do you know?
Not sure but I think it would as aren't they the same coily fitment as 6n's and 6n2's
There is someone breaking a red mk2 golf on here in the cars breaking send him a message and ask how much for the hubs
I just checked some pictures out of the 2 and they look identical apart from the angle in which the ball joint bolts up so i ordered a set off ebay for £38 posted. If they don't fit ill just have to sell them on again ha. Cheers for all your help pete i appreciate it.
It's alright mate glad I could help
Will mean your track will be slightly wider now only by about 10-15mm but nothing bad so will have to alter the track ends abit to suit
hope it all works
Edited by StinkyPete
Okay great ha, ill get some pics up when I've got them fitted. "When" been the operative word lol.
Just bought a few new parts, a few ebay pictures just for my records ha.
Porsche Horn Press
WIDE Plastic Bucket Seat so i actually fit in it ha
MK2 Golf Hubs For The New Brakes
All Red Rears
GTI Servo
And the last piece to the brake jigsaw. 305mm Ibiza discs. Lets hope that the mk2 hubs fit. Complete new braking system and wheel bearings all round for 2013 ha.
Are them discs 4 stud like it says and what's the minimum size wheel you would need with them mate
You got a link to the discs please
Ye 4 stud mate, 16" minimum wheel i think. Ebay link is:
http://www.ebay.co.uk/itm/FRONT-GROOVED-BR...=item4606e8ec4d
