VR6 Turbo
Just gone into my files and my M.O.T and tax has ran out. Going to get the Log Book changed to a 2.8 while its off road. Wish me luck lol.
  • Replies 1k
  • Views 114.1k
Just been round to garage for frist time in about a month ha.
My engines going rusty and growing mould on it lol
Poly-carbonate sunroof
Poly-carbonate Rear Quarter Windows
Momo 280mm Steering Wheel With Porsche Horn Press
Seats
Stock Pile Of Parts - 4 New Bearings Porsche calipers, adapters, braided hoses, rear discs, Green Stuff Pads
Liking this mate, laid back kinda driver i assume giving the seat position lol.... Good luck with it :D
Cheers mate, no they're not mounted in yet and they're top heavy so wouldn't stand up for the pic lol. Think I'm going to sell the drivers one now and replace it with 1 the same as the passenger side though.
haha, i was messing i guess as much :p
Ahh, passengers one better? drivers looks to be the same as fitted to alot of kitcars?
Oh ye lol. Ye that's the ones mate I've seen them in a lot of kit cars too. VERY uncomfortable and very narrow for the larger kid haha. The are 3kg lighter than the other ones but I'm willing to add that to the weight of the car in order for some comfort lol.
haha, whats the pasengers one made of? looks like a seat insert and looks like its made of rubber lol.
Haha, no its just made from good old thick Plastic lol. Really comfy to sit in though.
How have you fitted your polly windows? Iv been looking for some sort of seal I can use but think ill need to bond them in
Looking good :D
Looking good :D
I got a window company to come out and prime them and bond them in. It only cost £40 for the 2 doing. A tube of tiger seal and a gun would have been £25 not to mention they wouldn't have been primed lol.
Looking good :D
I was going to get some bike screen bolts iv got loads in the garage, and find a window seal that would work with it.. Good plan getting a company in though. Costs a little more and less hassle
Ye that was my thoughts exactly. I didn't have to lift a finger ha
Got fed up of black so just done this with a rattle can i had laying about, what you think??? i might go white yet though, not sure. Obviously they'll be done properly when i find what colour i want them ha
19361B13-BE8B-4DC8-A02E-DD05D918AACF-159
3B7C9773-4EF4-450C-BA3B-157F3487407E-159
Edited by polovr6man
Just been in contact with Mr ADAPTORMAN and he's coming wednesday to measure up for the turbo fitment. Sweet as a nat
Front Bearing are in the new hubs. Nothing worth picture time though lol.
will the mk2 golf hubs work then ;)
I'm still not sure mate, i havn't tryed to fit them yet. Ill get some pics of one close up now though to show the difference in angle of dangle lol
Should clear the ball joint easily as long as the hub its self fits onto the polo lol. Nice back plates aren't they ha
A89CAE8D-33B9-4988-B2E8-E4D4A9E537DE-268
New Bearing Fitted
FB7E0381-37F8-4DF3-B25B-8F789A57A59C-268
Adaptormans been today. Tubular manifold is coming along nicely. May be a picture update tomorrow when more has been added to it. At the minute its just a flange with a few pipes welded to it so not really photogenic lol
The silver looks alot better. :-) coming along well. Looka ace. Would love to have a go in it!
Edited by Sonny1day
Haha, ill take you in it if i see you at a show lol. I think I'm going white with them now.
Right, just been round to the garage to fit the bigger brakes and i can't as the ball joints are different and the wheels won't go over them. Anybody know where i can get some custom ball joints?
Polo 16v Ball joint is threaded with a nut on top
Mk2 golf ball joint has a pinch bolt that runs through it
I need a polo base with a mk2 golf shaft on it. Is there a part out there which already exists? Cheers
Now then fella what you will need to do is run a mk3 golf or mk2 hub and outer c.v but the issue is the ball joint, the bolt hole dont line up to the polo arm so you have to re shape the end of the arm but that is a long shot tbh or another way is to. Use 9n ball joints and get the mk2/3 ball joint pressed into the casing so you mixing golf with polo just to get it right but i don't
know who does anything like that with ball joints local.
Okay cheers mate, i don't know if their a fixed unit or if you can push the centre out of one and replace it with a mk2 golf one? Not sure if it will just damage it.
Just ordered these 25mm spacers so that my wheels will fit. Just the ball joint problem to solve now. Hmmmmm
You could get the polo ones and get the ball joint adapted check my thread about my rear tcas as I used escort adjustable ones which have the thread like your polo ones but as I'm running ml1 golf hubs I needed a pinch bolt ball joint
So I made some adapters that screw onto the thread and taper and convert it to the pinch bolt type
I made mine from stainless but they may be better made from some en19t or en24t steel then heat treated for hardness and durability
I will probably make myself some more out of that material as I need to make some more for my front tcas too as il be using the same escort tcas on the front
Hope this helps
