VR6 Turbo
I may need the front arches doing, i haven't took it off the axle stands yet to see how it sits lol. It will be lock to lock that i have problems if anything but 1/4 miles in a straight line ha. It owes me loads mate, feel sick thinking about it.
  • Replies 1k
  • Views 114.1k
Wow, just took it off the stands and its definitely going to scrape over bumps on the front lol. Also, imagine your sat in the drivers seat looking at the front wheels, they're at 10 to 2 ha. Both facing outwards by a long way due to the mk2 hubs. Might not even make it to the garage i use to track it up at this rate. Got plenty done today though, pleased. Picture updates tomorrow.
Edited by polovr6man
Whos to say theres enough thread n the track rod ends, go too far and it'll be plain dangerous. fucked up ackerman y0000
I know ha, possibly not enough. I may need some custom track rod ends.
Right a few pics here of a few parts for my records:
Some straight 38mm pipe for tubular manifold and got my self a new set of performance leads as the old ones were getting a bit worse for ware
A pic of my new rear braided hoses
And just ordered some silicone brake fluid (as recommended by Pete)
thats the exact same fluid il be getting let me know how you get on with it mate
and for the steering you could look into using mk2 golf arms on your steering rack just an idea
I'm going to be putting a full mk2 golf steering rack and column in mine to match the mk2 front track width il be running seems easier for me to do this
Okay mate ill let you know ye. Might have to use some different arms yeah, ill cross that bridge when i come to it ha, need to get this bleedin turbo in place first.
Right forgot the pics again ha, got my seat mounted and in for good lol. Perfect driving position
Mount Drivers Seat
Buy Seat for Passenger Side and Fit it
Fix Bonnet Down
Make Tubular Manifold and Mount turbo to it
Mount Fibreglass Tailgate When its back from paint shop
Buy Some Propper Tyres
Fit new brakes
Buy Some Heat Wrap For Exhaust
Buy The 2 Braided Hoses I Need
Buy some perspex for tailgate and fit it
Buy and fit cupra brake fluid reservoir
Get it Tracked up
Get wheels painted white
Tax and Test It
Get It Re-mapped
Finally got some pictures ha, off to Belgium for the weekend now so no updates until tuesday
Seat welded in
All red rears fitted
New Lexan windows in that actually fit properly
Brake fluids arrived. Just gone to change the master cylinder and the nipple ends are a different size on the gti. Going to get some braided hoses made up for it, it will look pretty under the bonnet as well ha. What part of the master cylinder is it that measures 22mm so i can check that its actually bigger that the one fitted?
toe in on rear wheels y0000 hehe.
Looking good mate, hows the front sit, any pics? :p
Haha, i haven't got any pics at the minute mate no, ill get some either tomorrow or Wednesday. The arches will be sat on the tyres over bumps i think ha.
Right got some pics of the rear set-up, the master cylinders and how the tyres sitting at the minute ha. Can anyone tell me which is the biggest MC or if they are the same just from the pics? Cheers
They will have a number written on them... i can see one says "20" on it. This will be a 20mm m/c. mines a 23.4
I can't believe that i didn't spot that ha. Ill go and check what the other one reads
Scrapped that idea I've bought a cupra MC same as you mate
Best way ;) How much did you get it for? Think mine was £18 or somewhere
I payed £33.50 ha, all because it already has the spacer with it. Saves me a job though
A few new parts for the records,
Another Plastic bucket seat for passenger side
German Passenger side All red rear minus Clear Reverse Bit
Cupra 23.4mm Master Cylinder plus conversion Plate
Mate were did you get the spacer for the stubby from am in need of one asap
Loving the progress mate,
That rear brake flexy looks on a bit of a shit angle though?
It is on a shit angle haha, i must have had 30 6n's in my time and i never realized that they have another flexi in between the rear one that goes to the caliper and the steel brake pipe that runs all the way to the front of the car. I'm going to my local hydraulic company before i add the fluid and I'm going to get quite a few braided hoses made up. It's the steel one in the pic that's the problem, its too long as it used to run a bit further along to the drums, but i thought i may as well get a braided hose made up which not only replaces the steel pipe, but that will incorporate the mystery flexi that I've never noticed before lol. Definitely agree on that one, shit angle all round ha.
You going to spring fest?
Cool man, :)
How rigid are the seats when mounted like that?
Will be going spring fest aye
