VR6 Turbo
Turbo fitment has begun, engine took out, new head gasket, head spacer guides and tensioners along with techniclutch fitted. Engine sat back in place, all ready for turbo bolting on tomorrow. Pic shows howmuch room there actually is now manifold and throttle body's off.
  • Replies 1k
  • Views 114k
Manifold bolted on, turbo's on, wastegate mounted, coil pack fitted, cam shaft sensor put it, silicone hoses in place and a few more bits got done today, i need to wait while monday now so i can go and get an oil feed made up. then injectors will be going in and ecu wired in. not much left to do then ha
Wow I want one . That looks sweet as bud . Hope it all going well . Looks hell .lol . Dave
cheers mate, I'm dying to give it a polish and clean it up but it will just keep getting muckier until its all fitted and complete so theres no point ha.
Sum more pics I've just found
Good work keep it up, boy it was all a dream at first till i woke up and seen you was there befor me :crybaby:
but just a few to help you along the way cos a tru dubber shears his knowlage and love,
dyn007_original_640_480_pjpeg_2614442_27
Haha, are these in england? i thought it would be the first vr6 turbo 6n in england, seen loads in germany though.
EDIT: They are foreign, just seen where the servo bolts to the bulkhead ha
Edited by polovr6man
Just polished rocker cover and ordered some polished nuts for it, also ordered t bolt clamps, v band and some silicone reducers
Awesome stuff mate
Looking good my friend . Rocker cover looks spot on to . You got much left to do ? Dave
Awesome stuff mate
Cheers mate
Cheers mate, ye theres quite a bit left to do still, you think your nearly there and something else crops up, today weev got oil feed from sump welded in place and sump bolted back up, custom screamer pipe made and fitted and the down pipes near enough made an bolted on but it got dark so it'l get finished tomorrow. We can then get injectors in and wired up and make an intake manifold to suit, ill keep the updates coming ha.
Got quite a bit done today, Down pipes finished and bolted up, scream pipes been extended to floor, the remaining water hoses have been coupled up, Wide band o2 sensor fed through floor, manual boost controller mounted and piped up, engine loom wired up, a few intercooler pipes are on, oil filter and plugs changed, the new oil will go in tomorrow when polished rocker nuts arrive. Injectors are in and oil returns on. Sum pics of how its looking:
nice work this is going to be an absolute weapon once its finished
Cheers mate, hopefully it will be if tuning goes to plan ha, i know its gunna be a ball ache though
what a monster!
Awesome mate, fair play for cracking on so fast lol.
8-)
Amazing bud that is a work of art , can wait to c it are you going to get to any shows this year with it ? If so I wouldn't mind having a look around it if possible ? Thanx . Dave
jud you are pics are crap lol , think i need glasses to try view them ,,,
here these better
now most basic things are sorted ill bring tig welder over and knock a intake up , and start on wireing harness/wideband
with that turbo will have a very quick rapid spool , so u might wont to upgrade you are seats too .
and underwear :lol:
what sort of psi are you looking at pushing through it?
ill start him off with no boost , do a rough base tunie , then stage 1 it at 8psi and work up from there , max would be a possible 21psi ,
Hats off to you mate, turbo's in a Polo just feels soooo right - Loving my 20vt right now...
Haha thanks for all the good comments lads, its nice to get some positive feedback. See if we can get an intake manifold made up tomorrow then so we can have a trial start ha
